电子发烧友论坛|
硬件平台:CC2541
软件环境:IAR for 8051 v8.20.2 协议栈版本:1.4.0 最近一个项目中,用了CC2541的广播模式(单一模式,不带从机或主机)。我是按照SimpleBLEBroadcaster的示例工程做的。 对广播数据的操作如下: /* 关闭广播 */ initial_advertising_enable = FALSE; GAPRole_SetParameter( GAPROLE_ADVERT_ENABLED, sizeof( uint8 ), &initial_advertising_enable ); /* 更新广播数据 */ GAPRole_SetParameter( GAPROLE_ADVERT_DATA, sizeof( advertData ), advertData ); /* 打开广播 */ initial_advertising_enable = TRUE; GAPRole_SetParameter( GAPROLE_ADVERT_ENABLED, sizeof( uint8 ), &initial_advertising_enable ); 虽然advertData[ ]的数据改变了,但是实际广播出来的数据没有任何变化,后来更改为更新数据之后,10ms再打开广播,还是不起作用。请帮我查看一下问题所在。 下面贴出初始化部分的代码: /* Setup the GAP Broadcaster Role Profile */ [ /* Device starts advertising upon initialization */ uint8 initial_advertising_enable = TRUE; /* By setting this to zero, the device will go into the waiting state after being discoverable for 30.72 second, and will not being advertising again until the enabler is set back to TRUE */ uint16 gapRole_AdvertOffTime = 0; uint8 advType = GAP_ADTYPE_ADV_SCAN_IND; // use scannable unidirected advertisements /* Set the GAP Role Parameters */ GAPRole_SetParameter( GAPROLE_ADVERT_ENABLED, sizeof( uint8 ), &initial_advertising_enable ); GAPRole_SetParameter( GAPROLE_ADVERT_OFF_TIME, sizeof( uint16 ), &gapRole_AdvertOffTime ); GAPRole_SetParameter( GAPROLE_SCAN_RSP_DATA, sizeof( scanRspData ), scanRspData ); GAPRole_SetParameter( GAPROLE_ADVERT_DATA, sizeof( advertData ), advertData ); GAPRole_SetParameter( GAPROLE_ADV_EVENT_TYPE, sizeof( uint8 ), &advType ); ] /* Set advertising interval */ [ uint16 advInt = DEFAULT_ADVERTISING_INTERVAL; GAP_SetParamValue( TGAP_LIM_DISC_ADV_INT_MIN, advInt ); GAP_SetParamValue( TGAP_LIM_DISC_ADV_INT_MAX, advInt ); GAP_SetParamValue( TGAP_GEN_DISC_ADV_INT_MIN, advInt ); GAP_SetParamValue( TGAP_GEN_DISC_ADV_INT_MAX, advInt ); ] /* Setup a delayed profile startup */ osal_set_event( smartTag_TaskID, ST_START_DEVICE_EVT ); |
5 个讨论
我今天试了一下,在中间加了100ms延时,再更新内容,还是不行。我之前用从机+广播模式,那时候是正常的,最近项目想把从机取消掉,我就参照着SimpleBLEBroadcaster示例程序修改。
广播事件类型改为GAP_ADTYPE_ADV_NONCONN_IND,这个是以前有从机模式的时候默认的,也还是不行。 还有一部分初始化的代码,请看一下,有没有缺什么东西: void osalInitTasks( void ) [ uint8 taskID = 0; tasksEvents = (uint16 *)osal_mem_alloc( sizeof( uint16 ) * tasksCnt ); osal_memset( tasksEvents, 0, ( sizeof( uint16 ) * tasksCnt ) ); /* LL Task */ LL_Init( taskID++ ); /* Hal Task */ Hal_Init( taskID++ ); /* HCI Task */ HCI_Init( taskID++ ); #if defined ( OSAL_CBTIMER_NUM_TASKS ) osal_CbTimerInit( taskID ); taskID += OSAL_CBTIMER_NUM_TASKS; #endif /* OSAL_CBTIMER_NUM_TASKS */ /* GAP Task */ GAP_Init( taskID++ ); /* Profiles */ GAPRole_Init( taskID++ ); /* Application */ SmartTag_Init( taskID ); ] |
为了造福大家,我还是自己回答自己吧!有用到的也可以来看看。 官方例程SimpleBLEBroadcaster,只用到了广播模式。以上的方法不正确。 正确做法: GAPRole_SetParameter( GAPROLE_ADVERT_DATA, sizeof( advertData ), advertData ); GAP_UpdateAdvertisingData( smartTag_TaskID, TRUE, sizeof( advertData ), advertData ); |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1723浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-1 19:47 , Processed in 0.814298 second(s), Total 68, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
28276
