电子发烧友论坛|
先贴上程序
void SkI2cInit (void) [ // The I2C0 peripheral must be enabled before use. ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_I2C0); ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOB); GPIOPinConfigure(GPIO_PB2_I2C0SCL); GPIOPinConfigure(GPIO_PB3_I2C0SDA); // Select the I2C function for these pins. This function will also // configure the GPIO pins pins for I2C operation, setting them to // open-drain operation with weak pull-ups. Consult the data sheet // to see which functions are allocated per pin. ROM_GPIOPinTypeI2C(GPIO_PORTB_BASE, GPIO_PIN_2 | GPIO_PIN_3); // Enable and initialize the I2C0 master module. Use the system clock for // the I2C0 module. The last parameter sets the I2C data transfer rate. // If false the data rate is set to 100kbps and if true the data rate will // be set to 400kbps. For this example we will use a data rate of 100kbps. ROM_I2CMasterInitExpClk(I2C0_MASTER_BASE, ROM_SysCtlClockGet(), false); ] void I2cWriteByte(unsigned char deviceID,unsigned char offset,unsigned value) [ ROM_I2CMasterSlaveAddrSet(I2C0_MASTER_BASE, deviceID, false); ROM_I2CMasterDataPut(I2C0_MASTER_BASE, offset); ROM_I2CMasterControl(I2C0_MASTER_BASE, I2C_MASTER_CMD_SINGLE_SEND); while(ROM_I2CMasterBusy(I2C0_MASTER_BASE)) [ ] ROM_I2CMasterDataPut(I2C0_MASTER_BASE, value); ROM_I2CMasterControl(I2C0_MASTER_BASE, I2C_MASTER_CMD_SINGLE_SEND); while(ROM_I2CMasterBusy(I2C0_MASTER_BASE)) [ ] ] unsigned char I2cReadByte(unsigned char deviceID,unsigned char offset) [ unsigned char value; ROM_I2CMasterSlaveAddrSet(I2C0_MASTER_BASE, deviceID, false); //This function will set the address that the I2C Master will place on the bus when initiating a //transaction. When the bReceive parameter is set to true, the address will indicate that the //I2C Master is initiating a read from the slave; otherwise the address will indicate that the I2C //Master is initiating a write to the slave. ROM_I2CMasterDataPut(I2C0_MASTER_BASE, offset);//Transmits a byte from the I2C Master ROM_I2CMasterControl(I2C0_MASTER_BASE, I2C_MASTER_CMD_SINGLE_SEND);//Controls the state of the I2C Master module. while(ROM_I2CMasterBusy(I2C0_MASTER_BASE))//Indicates whether or not the I2C Master is not-busy. [ ] ROM_I2CMasterSlaveAddrSet(I2C0_MASTER_BASE, deviceID, true); ROM_I2CMasterControl(I2C0_MASTER_BASE, I2C_MASTER_CMD_SINGLE_RECEIVE); while(ROM_I2CMasterBusy(I2C0_MASTER_BASE)) [ ] value=ROM_I2CMasterDataGet(I2C0_MASTER_BASE);//Receives a byte that has been sent to the I2C Master. return (value); ] //***************************************************************************** // // Print "Hello world!" to the UART on the Stellaris evaluation board. // //***************************************************************************** int main(void) [ unsigned char buffer=0; // // Set the clocking to run directly from the crystal. // ROM_SysCtlClockSet(SYSCTL_SYSDIV_1 | SYSCTL_USE_OSC | SYSCTL_OSC_MAIN | SYSCTL_XTAL_16MHZ); // // Initialize the UART. // ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA); GPIOPinConfigure(GPIO_PA0_U0RX); GPIOPinConfigure(GPIO_PA1_U0TX); ROM_GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1); UARTStdioInit(0); SkI2cInit(); // Hello! // UARTprintf(" 33[2JHello World!n"); while(1) [ //I2cWriteByte(0x64>>1,0x08,0x23); buffer=I2cReadByte(0x64>>1,0x08); UARTprintf("Received:%02xn",buffer); ] ] 以下是此芯片的I2C时序 现在我单独调用I2cReadByte();通过串口打印UARTprintf()能读到该芯片的ID寄存器以及其他默认不为0的寄存器的值; 但是我先用I2cWriteByte();写某个寄存器,再用I2cReadByte();读出这个寄存器的值发现读不到这个寄存器的值,很奇怪,请大家帮我分析分析 另外Stellaris® Peripheral Driver Library USER’S GUIDE 文档中 “I2CMasterControl()” 此函数的用法大家有详细说明吗?以下命令: I2C_MASTER_CMD_SINGLE_SEND I2C_MASTER_CMD_SINGLE_RECEIVE I2C_MASTER_CMD_BURST_SEND_START I2C_MASTER_CMD_BURST_SEND_CONT I2C_MASTER_CMD_BURST_SEND_FINISH I2C_MASTER_CMD_BURST_SEND_ERROR_STOP I2C_MASTER_CMD_BURST_RECEIVE_START I2C_MASTER_CMD_BURST_RECEIVE_CONT I2C_MASTER_CMD_BURST_RECEIVE_FINISH I2C_MASTER_CMD_BURST_RECEIVE_ERROR_STOP I2C_MASTER_CMD_QUICK_COMMAND I2C_MASTER_CMD_HS_MASTER_CODE_SEND 都是怎么用的? 非常感谢! |
4 个讨论
楼主,
I2C从设备的寄存器是可读的吧。 我觉得可能还是因为没有按照从设备的I2C寄存的读取规范。至于楼主列的那些命令的含义,楼主可以参考stellarisware里面的driverlib中的源代码,这几个命令其实就是代表着往寄存器I2CMCS中写入的值, 楼主可以参考下面的值,在datasheet的表15-5(Write Field Decoding for I2CMCS[3:0] Field)中查找相应值的含义。 #define I2C_MASTER_CMD_SINGLE_SEND 0x00000007 #define I2C_MASTER_CMD_SINGLE_RECEIVE 0x00000007 #define I2C_MASTER_CMD_BURST_SEND_START 0x00000003 #define I2C_MASTER_CMD_BURST_SEND_CONT 0x00000001 #define I2C_MASTER_CMD_BURST_SEND_FINISH 0x00000005 #define I2C_MASTER_CMD_BURST_SEND_STOP 0x00000004 #define I2C_MASTER_CMD_BURST_SEND_ERROR_STOP 0x00000004 #define I2C_MASTER_CMD_BURST_RECEIVE_START 0x0000000b #define I2C_MASTER_CMD_BURST_RECEIVE_CONT 0x00000009 #define I2C_MASTER_CMD_BURST_RECEIVE_FINISH 0x00000005 #define I2C_MASTER_CMD_BURST_RECEIVE_ERROR_STOP 0x00000004 #define I2C_MASTER_CMD_QUICK_COMMAND 0x00000027 #define I2C_MASTER_CMD_HS_MASTER_CODE_SEND 0x00000011 |
sunguodong 发表于 2019-9-3 13:22 寄存器是可读写的,而且I2C的读写时序(帖子中已经贴出来了)也是对的。我在TI源代码中找找看相关例子 |
如果楼主对时序理解正确,我觉得就是几个命令字使用的问题了,建议楼主研究一下命令字的含义,我列出几个楼主可能可以用到的,然后按照时序图应该就可以了: I2C_MASTER_CMD_SINGLE_SEND: start, data和stop相都有的 I2C_MASTER_CMD_SINGLE_RECEIVE :start, data和stop相都有的 I2C_MASTER_CMD_BURST_SEND_START :有start和data相,没有stop相 I2C_MASTER_CMD_BURST_SEND_CONT:只有data相, I2C_MASTER_CMD_BURST_SEND_FINISH :有data相和stop相,没有start相 I2C_MASTER_CMD_BURST_SEND_STOP :只有stop相 I2C_MASTER_CMD_BURST_RECEIVE_START, I2C_MASTER_CMD_BURST_RECEIVE_CONT,I2C_MASTER_CMD_BURST_RECEIVE_FINISH ,I2C_MASTER_CMD_BURST_RECEIVE_ERROR_STOP可以参考上面 |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1723浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-1 19:33 , Processed in 0.940216 second(s), Total 62, Slave 49 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1171
