电子发烧友论坛|
我有一个34972A,我正试图连接到我们的局域网。
我通过检查计算机是否能够连接到网络来验证网络端口和电缆(位于集线器上)的连接。 当我把仪器放在这个端口上时,它无法获得一个IP地址,最终会自动配置一个169.254.x.x地址。有什么建议可以连接它吗? 以上来自于谷歌翻译 以下为原文 I have a 34972A which I'm trying to hook up to our LAN. I have verified connectivity of the network port and cable (which is on a hub) by checking that a computer is able to connect to the network. When I put the instrument on this port it is not able to get an IP address and eventually it will auto-configure a 169.254.x.x address. Any suggestions to get this connected? |
1个回答
您好,我对Agilent 34972A数据记录仪存在类似问题。
它不需要启用DHCP的IP。 它曾经不时地产生问题,但最近它根本不需要知识产权。 我试图手动配置它,但仍无法通过网络访问。 昨天我们决定进行固件更新,在我们完成之后,它“立即”获取了DHCP分配的IP。 今天,当我们启动仪器时,它不再需要IP。 所以我们用IE连接到它的内部页面,在我们这样做之后,它再次起作用。 可能是什么问题? 要求每天管理员权限更改计算机的IP,将电缆更改为交叉电缆,以便能够直接连接到仪器的页面,以使其工作,这并不好笑。 我提到网络只有交换机,所以应该没问题。 谢谢你的建议。 以上来自于谷歌翻译 以下为原文 Hello, I'm having a simmilar problem with an Agilent 34972A Data Logger. It does not take an IP with DHCP enabled. It used to create problems every now and then, but lately it doesn't take an IP at all. I tried to have it manualy configured, but still not reachable through the network. Yesterday we decided to have a firmware update, and after we did it, it took the DHCP assigned IP "instantly". Today, when we powered up the instrument, it would not take IP again. So we connected to it's internal page with the IE, and after we did that, it worked again. What can be the problem? It's not funny to request every day admin rights to change the IP of the computer, change the cables to crossover ones, to be able to connect directly to the instrument's page, in order to make it work. I mention that the network has only switches, so it should be no problem. Thanks for any advice. |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 04:04 , Processed in 0.711791 second(s), Total 71, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2040
