电子发烧友论坛|
我有一个输入板在某些模式下用作时钟,并在其他模式下用作数据。
当我将输入焊盘连接到不同寄存器的时钟和数据时,我收到错误,这意味着无法路由。 当我按照建议在.ucf文件中使用CLOCK_DEDICATED_ROUTE时,PAR会运行很长时间并且失败并显示以下警告: 警告:地点:1137 - 此设计不保证可路由! 此设计包含一个全局缓冲区实例,驱动网络,驱动以下(前30个)非时钟加载引脚。 这不是Spartan-6中推荐的设计实践,因为全局布线的限制可能导致过度延迟,歪斜或不可路由的情况。 建议仅使用BUFG资源来驱动时钟负载。 请特别注意此路径的时间和路由,以确保满足设计目标。 这通常是一个错误,但CLOCK_DEDICATED_ROUTE约束已应用于COMP.PIN,允许您的设计继续。 此约束禁用与指定的COMP.PIN相关的所有时钟布局器规则。 我想知道可以在spartan6中实现这样的电路吗? 或者,有没有替代品? 以上来自于谷歌翻译 以下为原文 I have an input pad serves as a clock in some mode, and serves as data in other mode. When I connect the input pad to clock and data of different registers, I received error which means this can not be routed. When I use CLOCK_DEDICATED_ROUTE in .ucf file as recommended, PAR runs long time and failed with this warning as follows : WARNING:Place:1137 - This design is not guaranteed to be routable! This design contains a global buffer instance, net, non-clock load pins. < PIN: ulink2a/Mmux_lclkin_t11.A5; > This is not a recommended design practice in Spartan-6 due to limitations in the global routing that may cause excessive delay, skew or unroutable situations. It is recommended to only use a BUFG resource to drive clock loads. Please pay extra attention to the timing and routing of this path to ensure the design goals are met. This is normally an ERROR but the CLOCK_DEDICATED_ROUTE constraint was applied on COMP.PIN constraint disables all clock placer rules related to the specified COMP.PIN. I want to know can such a circuit be implemented in spartan6 ? or , is there any replacement ? |
1个回答
sanhu写道:
我有一个输入板在某些模式下用作时钟,并在其他模式下用作数据。 我想知道可以在spartan6中实现这样的电路吗? 或者,有没有替代品? 不,你不能在斯巴达6中做到这一点。 解决方法是将输入信号驱动到两个不同的引脚,当然其中一个是全局时钟输入引脚。 ----------------------------是的,我这样做是为了谋生。 以上来自于谷歌翻译 以下为原文 sanhu wrote:No, you cannot do that in a Spartan 6. A workaround would be to drive that input signal into two different pins, one of course being a global clock input pin. ----------------------------Yes, I do this for a living. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 13:38 , Processed in 0.861992 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
9391
