扫一扫,分享给好友
您好我在之前的项目中使用了Virtex 6并使用了我以100 MHz运行的DNA端口。现在我尝试在Digilent Atlys Board上使用与Spartan 6-45相同的模块,并且我得到500 ns的极端偏差
然后我开始阅读勘误并得到一点困惑,因为ist说它在某些设备上不支持。有人知道它是否与Atlys主板上的斯巴达6 FPGA完全一样......? 以上来自于谷歌翻译 以下为原文 Hello i used the Virtex 6 in a previous Project and used the DNA Port which i ran at 100 MHz. Now i tried to use the same module with the Spartan 6-45 on the Digilent Atlys Board and i got an extreme skew of 500 ns. Then i started reading the errata and got a Little confused as ist says that it is Not supported on some devices. Does anyone know if it is definatly the same with the spartan 6 FPGAs on the Atlys boards...? |
5个回答
EN113,115,117,118
哪个勘误有问题? 每个都有受影响的零件表。 您必须检查零件的标记以查看它是否在列表中。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 EN113, 115, 117, 118 Which errata is in question? Each has a table of parts affected. You would have to examine the markings of the part to see if it is on the list. Austin Lesea Principal Engineer Xilinx San Jose |
EN 117我猜。
Atlys FPGA是:采用324引脚BGA封装的XilinxSpartan®-6 LX45 FPGA。 那么问题是它是否类似于XC6SLX45-2CSG324CES JTAG ID 1? 以上来自于谷歌翻译 以下为原文 EN 117 i guess. And the Atlys FPGA is: Xilinx Spartan®-6 LX45 FPGA in a 324-pin BGA package. So the question is if it is similar to the XC6SLX45-2CSG324CES JTAG ID 1? |
G,
听起来很合适(封装,引脚数量不重要,它是CES名称和JTAG ID号)。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 g, Sounds like it applies (the package, number of pins is not important, it is the CES designation, and the JTAG ID number). Austin Lesea Principal Engineer Xilinx San Jose |
有用!
修订版4。 现在我需要用2 MHz读取它,由于输入为100 MHz,因此难以生成,因此我应该创建10 MHz并将其提供给第二个DCM以生成2 MHz? 以上来自于谷歌翻译 以下为原文 It works! Its Revision 4. Now i need to read it out with 2 MHz, which uld be hard to generate as the input is 100 MHz so should i create 10 MHz and give it to a second DCM to generate 2 MHz? |
2 MHz
可能是DCM的频率太低。 我只想用一个计数器来分解它。 7月4日大家快乐! Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 2 MHz May be too low a frequency for a DCM. I would just use a counter to divide it down. Happy July 4th everyone! Austin Lesea Principal Engineer Xilinx San Jose |
只有小组成员才能发言,加入小组>>
2322 浏览 7 评论
2734 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2217 浏览 9 评论
3295 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2369 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
655浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
463浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
222浏览 1评论
669浏览 0评论
1861浏览 0评论
GMT+8, 2024-10-1 08:11 , Processed in 1.535688 second(s), Total 86, Slave 70 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
