嗨,
我尝试在Spartan 6 xc6lx75-3csg484上实现内存控制器,但它暂时不起作用。 我有NANY-NT5CB64M16FP它是128mb ddr3 Sdram。 我正在寻找一个有效的例子。 想想很多。 以上来自于谷歌翻译 以下为原文 Hi, I try to implement memory controller on Spartan 6 xc6lx75-3csg484 but it doesn’t work for the moment. I have NANY- NT5CB64M16FP it’s 128mb ddr3 Sdram. I’m looking for one example which works. Think a lot. |
4个回答
检查以下链接,了解sp605板的DDR3设计
https://secure.xilinx.com/webreg/clickthrough.do?cid=181980&license=RefDesLicense&filename=sp605_MIG_rdf0029_13.4_c.zip&languageID=1 --Krishna 以上来自于谷歌翻译 以下为原文 check the following link for the DDR3 design for sp605 board https://secure.xilinx.com/webreg/clickthrough.do?cid=181980&license=RefDesLicense&filename=sp605_MIG_rdf0029_13.4_c.zip&languageID=1 --Krishna |
嗨,
请通过UG388获取支持的内存设备列表。 我认为Nanya不是赛灵思的硬件评估,所以我们不能保证它的工作原理。 但你没有提到什么不起作用。 由于你不能为Nanya部分生成MIG,你可以使用自定义部件,请检查所有的时序参数是否按照nanya数据表正确设置。 通过UG的调试部分,确定哪个校准阶段失败以及是否有任何数据错误 确保您的时钟和复位电路正确并且符合电路板布局指南 在主AR下面,按照概述的步骤操作。 http://www.xilinx.com/support/answers/40775.html 希望这可以帮助 问候, Vanitha -------------------------------------------------- -------------------------------------------请在发布前进行谷歌搜索, 您可能会找到相关信息。请留下帖子 - “接受为解决方案”,如果提供的信息有用且回复,请给予赞誉 以上来自于谷歌翻译 以下为原文 Hi, Please go through UG388 for list of Supported memory devices. I think Nanya is not hardware evaluated by Xilinx so we cannot assure that it works. But you have not mentioned what is not working. As you cannot genearte MIG for Nanya part you would have use custom part, please check if all the timing parameters were properly set as per nanya datasheet. Go through Debugging section of UG and figure which stage of calibration is failing and if any data errors Make sure your clocking and reset circuitry is proper and board layout guideliness were met Go through below master AR and follow the steps outlined. http://www.xilinx.com/support/answers/40775.html Hope this helps Regards, Vanitha --------------------------------------------------------------------------------------------- Please do google search before posting, you may find relavant information. Mark the post - "Accept as solution" and give kudos if information provided is helpful and reply oriented |
想想,我听从了你的帮助。
现在MIG正在工作。 现在我的控制器MIG 输入I有8位数据和7位addr。 内存返回总是FF不明白 我的代码是吼叫 gestion_com.vhd 4 KB 以上来自于谷歌翻译 以下为原文 Thinks, I followed your help. now MIG are working. Now my controller MIG Input I have 8 bits data and 7 bits addr. The memory returns always FF don’t understand My code is bellow gestion_com.vhd 4 KB |
你的意思是说默认MIG正在工作,但你看到自己的流量出现数据错误?
如果是,请按照命令,在UG388中写入和读取时序图,并对信号进行交叉检查。 如果这是在HW,我建议您在模拟中验证。 -------------------------------------------------- -------------------------------------------请在发布前进行谷歌搜索, 您可能会找到相关信息。请留下帖子 - “接受为解决方案”,如果提供的信息有用且回复,请给予赞誉 以上来自于谷歌翻译 以下为原文 You mean to say default MIG is working but you see data errors with your own traffic? If yes please follow the command, write and read timing diagrams in UG388 and cross check against your signals. If this is in HW I would sugget you to verify in simulation. --------------------------------------------------------------------------------------------- Please do google search before posting, you may find relavant information. Mark the post - "Accept as solution" and give kudos if information provided is helpful and reply oriented |
只有小组成员才能发言,加入小组>>
2429 浏览 7 评论
2831 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2298 浏览 9 评论
3378 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2468 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
1337浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
595浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
459浏览 1评论
2012浏览 0评论
737浏览 0评论
GMT+8, 2024-12-28 13:45 , Processed in 1.438905 second(s), Total 84, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
