我试图在我的BootloadDead应用程序中实例化一个UART模块,但是一旦模块放到PSoC中,它就不会进入可引导加载的应用程序,而是停留在引导加载程序中。
我使用的UART Bootloader Guiand项目提供的塞浦路斯为基础。参见AN68 以上来自于百度翻译 以下为原文 I am trying to instantiate a UART module in my bootloadable application but as soon as the module is placed into the PSoC does not enter the bootloadable application but stays in the bootloader. I am using the UART Bootloader GUI and project supplied by Cypress as a basis. See AN68272 for a reference |
6个回答
你已经独立地建立了BL应用程序和UART
物理层符合RS232级,UART设置为3线无流量控制, PSOC和PC端可能有9600波特? 问候,Dana。 以上来自于百度翻译 以下为原文 You have established BL application works independently and that UART physical layer meets RS232 levels, UART set up as 3 wire no flow control, maybe 9600 baud on both PSoC and PC side ? REgards, Dana. |
Dana
是的,我已经确定项目是独立工作的,而不是一个可引导加载的项目。如果UART模块从项目中移除,则可引导加载项目是成功的。我增加了其他通信设备,也没有收到同样的问题。 至于UART配置,是的,这就是我正在使用的项目。 谢谢, 派克靴 以上来自于百度翻译 以下为原文 Dana, Yes I have established that the project works independently but not as a bootloadable project. The bootloadable project is successful if the UART module is removed from the project. I have added other communication devices and not received the same issues as well. As for the UART configuration yes those are what I am using for the project. Thanks, Pac |
我对你的描述有点困惑。通信端口应该放置在引导加载程序中,而不是在引导加载项目中。
以上来自于百度翻译 以下为原文 I am a little confused about your description. The communication port should be placed in bootloader, but not in the bootloadable project. |
您可以使用Bootloader和BootloadProject相同的通信接口。因为在给定的时间,只有一个程序部件是活动的,它们不相互影响。即使接口的参数可能彼此不同,初始化例程也会关心这一点。
鲍勃 以上来自于百度翻译 以下为原文 You may use the same communication interface for the bootloader and for the bootloadable project. Since at a given time only one of the program parts is active they do not influence each other. Even the parameters for the interface may differ from each other, the initialization routines will care for that. Bob |
在我的BooToad程序中,我更希望使用AuART来满足我的通信需求。问题是,如果在我的BootloadProject中实例化一个UART模块,Bootloader永远不会传递到我的BootloadDead程序。
我曾为我的bootloader的相同结果USB或串口通讯模块之间的切换。我会尽快删除UART从我的项目是成功的,bootloadable bootloader将控制传递到bootloadable。 在这一点上,我想知道如果有一个已知的问题与一个UART组件的PSoC和bootloadable应用。我也尝试与其他组件的USBUART工作预期。如果它是一个固定的功能模块而UDB组件具有相同的问题,UART的I2C器件是成功的,在bootloadable从未成功加载。 如有任何指导,将不胜感激。我的客户设计了他的项目,希望UART通信。 以上来自于百度翻译 以下为原文 I would prefer to use a UART for my communication needs in my bootloadable program. The issue is if I instantiate a UART module in my bootloadable project the bootloader never passes onto my bootloadable program. I have tried switching between a USB or UART communication module for my bootloader with the same results. As soon as I delete the UART from my project the bootloadable is successfull and the bootloader passes control onto the bootloadable. At this point I am wondering if there is a known issue with the PSoC and bootloadable applications with a UART component. I have also experimented with other components the USBUART works as expected. The I2C component is successful if it is a fixed-function module but the UDB component has the same issue as the UART, where the bootloadable is never successfully loaded. Any Guidance would be appreciated. My client designed his project expecting UART communication. |
这似乎是来自柏树技术支持的问题:
现在请检查BooLoad项目中“存储在ECC内存中的配置数据”选项。现在,清理和构建所有项目-gt;程序Bootloader & &;使用AAN6262提供的主机应用程序引导加载。 以上来自于百度翻译 以下为原文 This seemed to be the issue, from Cypress Technical Support: Now please un-check the option "Store Configuration Data in ECC Memory" of the Bootloadable project. Now clean and build All projects-> Program Bootloader -> Bootload using the Host Application provided with AN68272. |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-1 20:39 , Processed in 0.768474 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3605
