电子发烧友论坛|
你好,
我有一个MimiPrim3。当板不使用12 V适配器外部供电时,它编程3210 EVE板。但是当12 V电源连接时,MIXPROG不识别该设备。它也变得非常热。 当做 多石的 以上来自于百度翻译 以下为原文 Hi, I have a mimiprog3. it programs the 3210 eval board when the board is not powered externally using 12 v adaptor. But when 12 v supply is connected the miniprog doesnot recognizes the device. Also it becomeres very hot. regards Rocky |
3个回答
你正在满足这些限制
以下是PSoCalEVE电源选项: 1。由微型发电机供电。2。由一个9 - 12V直流壁变压器与正尖端桶塞和100毫安或更高的评级。推荐的型号是CUI公司,EPAS 101W-12。三。由9V电池供电,连接到电池端子。4。从插座中的冰袋供电。一次只能使用一个电源。不要使用小于9V或超过12V的电源。 Wallwart是DC,不是阿克特?检查范围。 当然,听起来像是调节器失灵了,PSoC正在被锁存。 当它闩住时,它会画出200毫安,耗散1W, 非常热的触摸。或者瓦瓦特内部的调节器失灵了。 问候,Dana。 以上来自于百度翻译 以下为原文 You are meeting these constraints - The following are PSoCEval power supply options: 1. Powered by the MiniProg unit. 2. Powered by a 9-12V DC wall transformer with positive tip barrel plug and a 100 mA or higher rating. Recommended model is CUI Inc., EPAS-101W-12. 3. Powered by a 9V battery connected to battery terminals. 4. Powered from the ICE pod in socket. Only one of the power supplies should be used at a time. Do not use a power supply that is less than 9V or exceeds 12V. Wallwart is DC, not AC out ? Check with scope. Sure sounds like regulator has failed and PSOC is getting latched up, when it latches up it will draw ~ 200 mA and dissipate ~ 1W, very hot to touch. Or regulator inside walwart has failed. Regards, Dana. |
这适用吗?
HTTP://www. CyPress?COM/?APP =论坛和ID ID=1573和;RID=54734 问候,L Dana。 以上来自于百度翻译 以下为原文 This apply ? http://www.cypress.com/?app=forum&id=1573&rID=54734 Regards,l Dana. |
你好,洛基,
当Rev * A有一些已知的缺点时,你有一个MyPrim3的Rev *或Rev *吗? 你也确保你没有在MixPrim3中启用电源吗? 当做, 最大似然估计 以上来自于百度翻译 以下为原文 Hello Rocky, Do you have a Rev *A or Rev *B of Miniprog3 as Rev *A has some known short comings? Also did you make sure you haven't enabled power in your MiniProg3 as well? regards, MSUR |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 03:19 , Processed in 0.691662 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2643
