扫一扫,分享给好友
你好,可以请人帮我,我想计划的cy3271-exp1 PSoC气象站板采用miniprog3这样我可以把周围的光强读数然后发送阅读通过串行命令我写的一个应用程序并存储的数据画成了GR促性腺激素释放激素我知道这是不能够使用PSoC Creator 2代替PSoC Designer??我可以知道如何安装与miniprog3气象站和如何使气象站板的工作吗?我试图连接销第3的气象站板的miniprog3 5引脚接口但当我选择调试目标PSoC Creator 2.0无法检测到任何设备。
以上来自于百度翻译 以下为原文 Hi, Can someone please help me, I would like to program the CY3271-EXP1 PSoC Weather Station board by using MiniProg3 so that I can take the reading of surrounding light intensity and then sent the reading through serial comms to an application I wrote and stored the data then draw it out into a graph. May I know if this is do-able using PSoC Creator 2.0 instead of PSoC Designer?? May i know how to setup the Weather Station with the miniprog3 and how to make the Weather Station Board work? I tried to connect Pin 1,3,5,7,9 of the Weather Station Board to the Miniprog3 5-Pin Interface but when i select debug target PSoC Creator 2.0 could not detect any device. |
3个回答
当你在不同的论坛上重复你的问题时,这并不是很有帮助,我相信你不会得到更好的/更快的回答。
鲍勃 以上来自于百度翻译 以下为原文 It is not very helpful when you double-post your question in different forums, I'm sure you won't get better / faster answeres. Bob |
CY套件3271是基于PSoC1的套件。PSoC Creator可用于仅编程PSOC3和PSOC5设备。是的,当您连接到3271时,您肯定无法找到PSoC Creator的调试目标,因为该设备不支持该软件。我相信,如果我没有错的话,有一个专用的气象监控器应用程序与工具箱相关。
以上来自于百度翻译 以下为原文 The CY Kit 3271 is a PSoC1 based kit. PSoC Creator can be used to program PSoC3 and PSoC5 devices only. Yes you will definitely not be able to find a debug target from PSoC Creator when you connect to a 3271 because the device is not supported y the software. I believe that there is a dedicated weather monitor application associated with the kit if I am not wrong. |
对不起,我不知道该怎么办,因为我不确定我该把问题放在哪里。有一个专门的软件应用程序被提供来监视Cy32 121-Exp1,如果我想对它编程,我理解我必须使用PSoCdSoCd.我听说PSoDeCAD只与PSoC 1而不是PSoC 3一起工作。因此,如果我的开发板在PSoC 3中,那么PSOC3和CY3171-EXP1之间可能会起作用吗?
以上来自于百度翻译 以下为原文 Sorry about the double posting as i'm not sure where should i put my problem at. There is a dedicated software appliation that is provided to monitor the CY 32271-EXP1 and if i want to program something to it i understand that i have to use PSoC Designer. And i'm told that PSoC Designer only works with PSoC 1 and not PSoC 3. So if my development board is in PSoC 3 is there anyway things might works between PSoC3 and the CY3271-EXP1? |
只有小组成员才能发言,加入小组>>
716个成员聚集在这个小组
加入小组1901 浏览 1 评论
1652 浏览 1 评论
3405 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1568 浏览 6 评论
1380 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
188浏览 2评论
184浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
323浏览 2评论
352浏览 1评论
63浏览 1评论
GMT+8, 2024-4-25 00:45 , Processed in 0.671060 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
