电子发烧友论坛扫一扫,分享给好友
你好,
我正在试图弄清楚我需要做什么来配置和 我可以使用两个开发板。 首先,我有一个Spartan 3开发板,我在回来时使用过 大学和我能够使用JTAG-USB电缆对其进行编程。 电缆 是从Digilent inc。购买的。 出于某种原因,每当我尝试 调用Xilinx ISE-12的影响,无法检测到该板。 所以我有一个Spartan3板,对个人开发非常有用 而我似乎无法与之交谈。 其次,我已经交给了Virtex-4 ML402开发板 评估,我想我应该问是否购买“平台电缆 USB2“会是理想的吗?我的意思是,有了这个,我假设我能够 用它配置Spartan3和ML402? 所以,如果你可以帮助解决这个问题,我的意思是,如果我这样做会花费225美元 购买它,但是,如果你认为有什么我可以做到的 JTAG-USB电缆工作? 最后,出于好奇,我们有什么方法或选择 在ML402中实际配置和编程FPGA? 我在读 ML402的用户指南,它表明系统ACE卡可以 用于通过JTAG端口对FPGA进行编程。 我不知道在何处引用任何介绍或逐步介绍如何使用ACE CompactFlash(CF)就此而言,如果可能的话,这意味着,没有必要购买 “平台电缆USB2”? 感谢您期待我的快速回复 来自你 诚挚 Ade Sanusi 以上来自于谷歌翻译 以下为原文 Hello, I'm trying to figure out what I need to do in order to configure and program two development boards at my disposal. First, I have a Spartan 3 Development board which I used while back in college and I was able to program this using a JTAG-USB cable. The cable was purchased from Digilent inc. For some reason, whenever I try to invoke Impact from Xilinx ISE-12, the board can't be detected. So I have a Spartan3 board which is very useful for personal development and I can't seem to talk to it. Second, I have been handed a Virtex-4 ML402 development board for evaluation and I thought I should ask if purchasing a "Platform Cable USB2" would be ideal? I mean, with this, I'm assuming I will be able to configure both the Spartan3 and the ML402 with it? So, if you can help address this, I mean, it would cost me $225 if I was to purchase it, but, if you think there is anything I can do to get the JTAG-USB cable working? Finally, just out of curiosity, what are the methods or choices we have to actually configure and program the FPGA in the ML402? I am reading the user guide for the ML402 and it states that the System ACE card can be used to program the FPGA through the JTAG port. I don't know where to refer to for any introduction or step-by-step on how to use the ACE CompactFlash (CF) for this, and if that was possible, does it mean, there is no need to purchase the "Platform Cable USB2"? Thanks in anticipation of your quick response as I look forward to hear from you. Sincerely Ade Sanusi |
3个回答
Digilent JTAG电缆传统上只与Digilent Adept配合使用,而不是iMPACT,但从ISE 12.x开始,您可以为Xilinx Tools安装Digilent插件。我不确定安装插件后两根电缆之间是否存在任何功能差异
,除非您使用旧版本的ISE。 我相信您可以使用CF插槽代替使用JTAG电缆进行编程,但如果您想使用ChipScope,SDK调试器等,仍然需要JTAG。 以上来自于谷歌翻译 以下为原文 The Digilent JTAG cable traditionally only worked with Digilent Adept and not iMPACT, but as of ISE 12.x you can install Digilent Plugin for Xilinx Tools. [size=11.6667px]I'm not sure there's any functional difference between the two cables once you've installed the plugin, unless perhaps you're using an older version of ISE. [size=11.6667px]I believe you can use the CF slot in lieu of programming with a JTAG cable, though JTAG is still required if you want to use ChipScope, the SDK debugger, etc. [size=11.6667px] |
谢谢你的。
我能够与我的主管交谈,我将订购Platform Cable USB 2.我相信通过这种方式,我们将能够配置任何主板。 阿德 以上来自于谷歌翻译 以下为原文 Thanks for yours. I was able to talk to my supervisor and I'll order the Platform Cable USB 2. I believe with that way we will be able to configure any board. Ade |
别担心。
前几天我给你发了一条关于它的私信。 以上来自于谷歌翻译 以下为原文 No worries. I sent you a private message about it the other day. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 17:52 , Processed in 0.897640 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1216
