电子发烧友论坛|
我在实验室计算机上安装Xilinx 11.2版时遇到问题。
我从Xilinx设计工具网站下载了用于32位Windows系统的11.2 ISE设计套件,我下载的名为“Xilinx_11.2_ISE_DS_nt”的解压缩文件夹文件是4.17 GB文件夹。 此文件夹中是否有某个目录或可执行文件将安装Xilinx 11.2?我尝试在此目录中打开名为“xsetup.exe”的可执行文件:“Xilinx_11.2_ISE_DS_nt direct swhelp ise11 112_ise wu replace installer” 但每当我打开可执行文件时都没有任何事 Xilinx 11.2无法安装。 我还要提一下,Xilinx 10.1目前已安装在实验室计算机上; 如果我们试图在同一台计算机上安装Xilinx 11.2,我不确定这是否会导致问题。 此致 兰迪 Umich EE Class 2011 以上来自于谷歌翻译 以下为原文 I'm having trouble installing Xilinx version 11.2 on our lab computer. I downloaded the 11.2 ISE Design Suite for a 32-bit Windows system from the Xilinx Design Tools website, and the unzipped folder file I downloaded called "Xilinx_11.2_ISE_DS_nt" is a 4.17 GB folder. Is there a certain directory or executable within this folder that will install Xilinx 11.2? I tried opening the executable called "xsetup.exe" in this directory: "Xilinx_11.2_ISE_DS_ntdirectswhelpise11112_isewureplaceinstaller" but nothing happens whenever I open the executable; Xilinx 11.2 does not install. I should also mention, Xilinx 10.1 is currently installed on the lab computer; I'm not sure if that would cause problems if we are trying to install Xilinx 11.2 on the same computer. Sincerely, Randy Umich EE Class of 2011 |
3个回答
Pozzisa,
提取11.2后,您将需要在顶层运行xsetup.exe。 你浏览的太深了,“Xilinx_11.2_ISE_DS_nt”中应该有一个xsetup.exe我还要注意11.2是对11.1的更新,因此你需要先安装11.1然后再使用你的11.2下载 必须将其更新为11.2。 迈克阮 以上来自于谷歌翻译 以下为原文 Pozzisa, Once you extract 11.2, you will want to run the xsetup.exe in the top level. You are browsing too deep, there should be a xsetup.exe within "Xilinx_11.2_ISE_DS_nt" I also would like to note that 11.2 is an update to 11.1 and therefore you will want to install 11.1 first and then use the 11.2 download that you have to update it to 11.2. Mike Nguyen |
谢谢迈克,这真的很有帮助,我很感激。
以上来自于谷歌翻译 以下为原文 Thanks Mike, that was really helpful, I appreciate it. |
HI,
在获取lincense文件之后安装11.2版本请求管理xilinx许可证的窗口请求本地路径我只在本地xilinx目录中提供了路径,但是它没有服用wat可能是问题 还有一点,有两个窗口说通过外部目录设置我必须做什么? 请尽快回复!!!! 以上来自于谷歌翻译 以下为原文 HI, Am installing 11.2 version after getting the lincense file the window which ask for manage xilinx licences ask for the local path for i gave the path in local xilinx directory only , but its not taking wat might be the problem and one more point there are two windows saying set through external directory which i have to do ? pls reply asap!!!! |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 17:28 , Processed in 0.973098 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
6415
