扫一扫,分享给好友
大家好,
这是一个UDP实现的16位定点CORDIC,用于计算给定角度的正弦和余弦。它在PSoC 3上被支持,并且可能(忽略警告)运行到33 MHz。我已经附上了一个演示项目与项目库,所以尝试运行它在CY8CKIT-1001 DEVKIT。 邮编 142.5 K 以上来自于百度翻译 以下为原文 Hello all, this is a UDB implementation of a 16-bit fixed point CORDIC for calculating the sine and cosine of a given angle. It is supported on PSoC 3 and can possibly (ignoring warnings) run up to 33 MHz. I've attached a demo project with the project library so try running it on the CY8CKIT-001 Devkit.
7个回答
很酷!如何将数据输入到UDB中,以及如何选择正弦/余弦计算?
以上来自于百度翻译 以下为原文 Very cool! how do you get the data into / out of the UDB, and how do you select sine / cosine calculation? |
由于它是相同的算法,同时计算正弦和余弦并一起检索。看一看(优秀的)文件。
用Stand()API给出初始计算角度。 鲍勃 以上来自于百度翻译 以下为原文 Since it is the same algorithm sine and cosine are calculated at the same time and retrieved together. Have a look at the (excellent) documentation. The initial angle to calculate from is given with the Start() API. Bob |
我喜欢那个部件!
有机会为PSoC5(LP)实现这一点吗? 鲍勃 以上来自于百度翻译 以下为原文 I like that component! Will there be a chance to implement this for PSoC5(LP) ? Bob |
谢谢大家。:)
是的,API和使用信息在附带的数据表中。只需调用启动(UTIN 16角)API即可开始计算。 最初我打算为PSoC3和PSoC5LP都支持这个组件,但我只有在PSoC3上验证它的机会。我希望能做到这一点时,我可以得到我的手上一个PSoC5LP,有时间来开发它。 以上来自于百度翻译 以下为原文 Thanks guys. :) Yes, the API and usage information are in the accompanying datasheet. You simply need to call the Start(uint16 angle) API to start the calculation. I originally intended for this component to be supported for both PSoC3 and PSoC5LP, but I've only had the chance to verify it on PSoC3. I Hope to get this done when I can get my hands on a PSoC5LP and have the time to develop it. |
你好,
非常感谢这个组件!喜欢看,有人这么做了。 也将有逆版本φ=f(正弦(φ),COS(φ)),以获得相位角之外的正弦和余弦?我为自己做了这件事,但在空间利用方面的努力很少,而且比你使用的DP还要多。 拜伊 弗兰兹 以上来自于百度翻译 以下为原文 Hi, many thanks for that component too! Love to see, someone did this. Will there also be the inverse version phi = f(sin(phi), cos(phi)) for getting phase angle out of sine and cosine? I did this for myself but with less to none efford in space utilization and a lot more DP in use than you . Bye Franz |
是的,弗兰兹,
我将制作反向版本并将其作为该组件的一部分添加到下一个版本中。 以上来自于百度翻译 以下为原文 Yes Franz, I'll be making the inverse version and adding it as a part of this component in the next version. |
只有小组成员才能发言,加入小组>>
743个成员聚集在这个小组
加入小组2013 浏览 1 评论
1773 浏览 1 评论
3564 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1706 浏览 6 评论
1474 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
387浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
272浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
365浏览 2评论
307浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
506浏览 2评论
GMT+8, 2024-10-2 08:17 , Processed in 0.884948 second(s), Total 57, Slave 51 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
