电子发烧友论坛|
你好,
我有一个定制的电路板,当我想对电路板进行编程时,它表示FPGA的器件ID是错误的。 确切的错误消息是: 信息:iMPACT:583 - '0':从设备读取的idcode与bsdl中的idcode不匹配File.INFO:iMPACT:1578 - '0':设备IDCODE:00000000000000000000000000000000INFO:iMPACT:1579 - '0':预期 IDCODE:00000010011000101000000010010011 这对我来说很奇怪,因为在项目选项中我选择了正确的设备。 有人知道如何解决或调试这个问题吗? 我正在使用ISE 11.5完整版。 可能是因为我的时钟在引脚M1(LHCLK)上? 以上来自于谷歌翻译 以下为原文 Hello, I've got a custom made board and when I want to program the board it says that the device ID of the FPGA is wrong. The exact error message is: INFO:iMPACT:583 - '0': The idcode read from the device does not match the idcode in the bsdl File. INFO:iMPACT:1578 - '0': Device IDCODE : 00000000000000000000000000000000 INFO:iMPACT:1579 - '0': Expected IDCODE: 00000010011000101000000010010011 this likes strange to me because in the project options I've selected the right device. Anybody got an idea how I can solve or debug this problem? I'm using ISE 11.5 complete version. Could it be caused by the fact that my clock is on pin M1 (LHCLK)? |
2个回答
用范围测试告诉我,我得到了一个很好的clk信号。
我已经改变了一些电线,以便clk被放在gclk上。 不幸的是,这并没有解决问题。 我知道我正在使用XC3s700AN,但是当我尝试初始化时,它给我的信息是:有许多未知设备被检测到。 链扫描测试给我下一条消息: 错误:iMPACT - 边界扫描链测试失败。 请检查设备之间的tdi-> tdo连接:'1'('xc3s700an')和电缆。 硬件配置中可能存在问题。 检查电缆,扫描链和电源连接是否完好,指定的扫描链配置是否与实际硬件匹配,以及电源是否足够并提供正确的电压。 电压水平还可以。 Xilinx编程器的颜色为绿色。 通过测量电压水平的第二次检查没有发现一些问题。 在不同的板上测试程序员工作正常。 以上来自于谷歌翻译 以下为原文 Testing with a scope told me that I get a nice clk signal. I've rerouted the with some wires so that the clk is put on on gclk. Unfortunality this didn't solved the problem. I know that I'm using the XC3s700AN, but when I try to initialize it gives me the message: There are many unknown devices being detected. A chain scan test gives me the next message: ERROR:iMPACT - Boundary-scan chain test failed. Please check tdi->tdo connection between device:'1' ( 'xc3s700an') and the cable . A problem may exist in the hardware configuration. Check that the cable, scan chain, and power connections are intact, that the specified scan chain configuration matches the actual hardware, and that the power supply is adequate and delivering the correct voltage. the voltage level is ok. The color of the Xilinx programmer is green. A second check by measuring the voltage levels didn't revealed some problems. Testing the programmer on a different board works fine. |
IMPACT报告了一个全零的IDCODE,表明JTAG连接不正确,特别是在TDO连接到电缆TDO之前链中的最后一个设备,如ERROR消息所示。
------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 IMPACT reported an IDCODE that was all zeros which indicates that the JTAG connections are not correct, particularly with the last device in the chain before the TDO is connected to the cable TDO as the ERROR message indicates. ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 07:40 , Processed in 0.728509 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
823
