电子发烧友论坛|
我们使用的是FOC SDK 4.0,评估板STEVAL-IHM039V1(STM32F415ZG)和400 V,1kV电机驱动器STEVAL-IHM025V1。
电机在没有机械负载的情况下工作,正交编码器作为位置反馈。控制转速可以从STMCWB中正常工作。 但是当请求更多2500转/分钟时,速度监控图表中要求的速度会上升,但电机的卷轴旋转大约保持2500转/分钟。 这是软件的限制吗? 我们要调整哪些参数(速度控制器,扭矩控制器,弱磁),以获得更高的转速? #stm32100-PMSM-FOC-SDK转速的转速 以上来自于谷歌翻译 以下为原文 We are using the FOC SDK 4.0, the eval board STEVAL-IHM039V1 (STM32F415ZG) and a 400 V, 1kV motor driver STEVAL-IHM025V1. The motor is working with no mechanical load and a quadrature encoder as position feedback. Controlling the rotation speed works fine from STMCWB. But when requesting more the 2500 rpm, the requested speed goes up in the speed monitoring graph, but the reel rotation of the motor stays a approximately 2500 rpm. Is this a limit of the software? What parameters ( speed controller, torque controller, field weakening, ) have we to tune, to get to a higher rotation speed? #stm32100-pmsm-foc-sdk-speed-rpm |
2个回答
Ciao Christian
首先,我们需要确保电机确实达到了它的极限,因为有些时候WB的一个小问题会造成混乱。实际上,如果将监视器 - >寄存器 - >测量的速度最大值设置为2500,则WB使测量饱和,但这只是可视化的问题。所以请用液晶显示屏检查电机是否真的限制在2500转/分钟。 之后,如果电机达到最大速度,则可能达到以下两个限制之一: - 最大电流 - 最大调制指数 在你的情况下,我怀疑第一个不是问题,因为你正在测试没有负载,所以你可能达到调制指数的限制。这意味着您正在向电机提供100%的可用总线,并且无法进一步加速。要验证它,您只需更改输入电压并验证达到的限制是否与直流电压值成比例。 这意味着您可以达到该直流母线电压的电机的phisycal额定速度。在这种情况下,超过此速度的唯一方法是通量减弱。 再见 梁咏琪 以上来自于谷歌翻译 以下为原文 Ciao Christian First of all we need to be sure that the motor has really reached it's limit because some time a little issue in the WB create confusion. Indeed if the monitor->register->measured speed max value is set to 2500 the WB saturate the measurement but it is just problem of visualization. So please check with the LCD that the motor is realy limited to 2500 rpm. After that, if the motor reach the maximum speed is possible that one of the two limit has been reached: - Maximum current - Maximum modulation index In your case I suspect that the first can't be the issue because you are testing with no load so maybe you reach the limitation in the modulation index. This mean that you are suppling 100% of the available BUS to the motor and it can't be further accelerated. To verify it you can simply change the input voltage and verify if the reached limit is proportional with the DC voltage value. This means that you reach the phisycal nominal speed of the motor for that DC bus voltage. In this case the only way to go above this speed is with flux weakening. Ciao Gigi |
你好吉吉
谢谢你的提示。 限制因素确实是母线电压。电机的额定总线电压为400 Vdc,评估套件的工作电压为300V。 并减少最大在场弱化时允许的电压导致更高的速度。 我们继续学习PMSM的控制 基督教 以上来自于谷歌翻译 以下为原文 Hello Gigi Thanks for your hints. The limiting factor is indeed the bus voltage. The motor is rated for a bus voltage of 400 Vdc, and the eval kit operates with 300V. And reducing the max. allowed voltage at field weakeing results in higher speed. We go on learning about the control of PMSM Christian |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 03:01 , Processed in 1.283626 second(s), Total 73, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2548
