电子发烧友论坛|
大家好,
我正在尝试使用STM32 MC PMSM FOC SDK v3.4库运行三相BLDC电机。我有最新的ST MC Workbench。我有以下问题: 当我启动电机时,它开始旋转,但我无法调节它的速度。无论我设定什么速度,我都会保持准确的速度。 只有当我将速度设置为低于大约1300 rpm时,电机才会停止,并且我会收到“速度反馈”错误。即使我将目标速度设置为0,电机也在旋转。 电机也消耗太多电流。它没有任何负载,所以最多需要100mA才能旋转。但它消耗1A并且只是因为我的电压源的电流限制为1A。 霍尔传感器,电流读数和电压检测工作正常。 哪里可能有问题? 非常感谢您的回复。 #BLDC转速调节 以上来自于谷歌翻译 以下为原文 Hello guys, I'm trying to run a three-phase BLDC motor with STM32 MC PMSM FOC SDK v3.4 library. I have the latest ST MC Workbench. I have a following problem: When I start the motor, it begins to spin, but I am unable to regulate a speed of it. I keeps an exact speed no matter what speed I set. Only when I set the speed lower than approximately 1300 rpm, the motor stops and I get a ''speed feedback'' error. Motor is also spinning even if I set target speed to 0. The motor also consumes too much current. It doesn't have any load on it so it should take maximum of 100mA to spin. But it consumes 1A and only because I have a current limit of 1A on my voltage source. Hall sensors, current reading and voltage sensing are working fine. Where could be a problem? Thank you very much for your responses. #bldc-speed-regulation |
1个回答
Ciao Gigi
感谢您的回复。我会尽快尝试并在此发布我的结果。 如果测量和观察到的角度不匹配,可能导致HALL位置解码不正确? 再次感谢Gigi。 以上来自于谷歌翻译 以下为原文 Ciao Gigi Thanks for your reply. I will try it as soon as possible and post here my results. In case that the measured and observed angles won't match, what could cause incorrect HALL position decoding? Thank you again Gigi. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 04:03 , Processed in 0.719160 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1496
