电子发烧友论坛|
嘿,
我已为MIG 2.2为Spartan 3AN板生成DDR2控制器。 CLK 132 MHz 数据宽度为16位,带数据掩码 没有DCM DCM创建时66 MHz输入高达132 MHz,另一个DCM用于90°转换我觉得没什么特别的 控制器在行为模拟中工作正常但我在路线后模拟中遇到了一些问题。 写入命令在两种模拟中都有效,但读取命令在后置放置模拟中不起作用。 我认为问题是data_valid信号和user_data_output信号。 当它应该变为'1'时,该信号变为'X'。 我已经搜索了一些解决方案,并找到了FIFO 0和1.我认为这个FIFO会产生一些延迟,并且dqs_div信号会为输入数据提供一些时序。 现在我不知道该怎么做,我有一个时序约束问题dqs_div_rst信号 ================================================== ==============================时序约束:NET“main_00 / top0 / dqs_div_rst”MAXDELAY = 0.46 ns; 1分析, 1检测到失败的网络.1检测到定时错误。最大净延迟为0.468ns .--------------------------------- ----------------------------------------------- Slack: - 0.008ns main_00 / top0 / dqs_div_rstError:0.468ns延迟超过0.460ns时序约束0.008nsFrom To Delay(ns)F18.I SLICE_X63Y81.G3 0.468 F18.I SLICE_X62Y80.G3 0.406 F18.I SLICE_X62Y81.F3 0.405 F18.I SLICE_X62Y81。 G4 0.444 F18.I SLICE_X63Y80.F3 0.436 F18.I SLICE_X63Y80.G2 0.467 ---------------------------------- ---------------------------------------------- 我没有改变这是MIG 2.2的例子。 在一些笔记中,我读到rst_dqs_in和rst_dqs_out信号创建一个循环。 在我的测试平台中,我使用rst_dqs_in作为dqs_in的输入: rst_dqs_in 以下为原文 Hey, I have generate a DDR2 Controller for the Spartan 3AN board with MIG 2.2. CLK 132 MHz data width 16bit with Data mask and without DCM The DCM is create with 66 MHz input up to 132 MHz and another DCM for shifting 90° I think nothing special The controller works fine in behavioral simulation but I have some problems in Post-Route simulation. Write commands works in both simulation, but read commands don't work in Post Place simulation. I think the problem is the data_valid signal and user_data_output signal. This signals becomes 'X' when it should go '1'. I have search for some solution why and find the FIFO 0 and 1. I think this fifos make some delays and with the dqs_div signal some timing for incoming data. Now I don't know what to do, I have one timing constrain problem the dqs_div_rst signal ================================================================================ Timing constraint: NET "main_00/top0/dqs_div_rst" MAXDELAY = 0.46 ns; 1 net analyzed, 1 failing net detected. 1 timing error detected. Maximum net delay is 0.468ns. -------------------------------------------------------------------------------- Slack: -0.008ns main_00/top0/dqs_div_rst Error: 0.468ns delay exceeds 0.460ns timing constraint by 0.008ns From To Delay(ns) F18.I SLICE_X63Y81.G3 0.468 F18.I SLICE_X62Y80.G3 0.406 F18.I SLICE_X62Y81.F3 0.405 F18.I SLICE_X62Y81.G4 0.444 F18.I SLICE_X63Y80.F3 0.436 F18.I SLICE_X63Y80.G2 0.467 -------------------------------------------------------------------------------- I have nothing changed this is the example from MIG 2.2. In some notes i'd read the rst_dqs_in and rst_dqs_out signals create a loop. In my testbench i used rst_dqs_in as input for dqs_in: rst_dqs_in<=rst_dqs_out; Is this correct? At the moment I can't flash my board I get a new in several days. So i can't test the programm in hardware. Is this only a simulation problem??? The READ commands with the Simulation model(micron) works fine. Have someone a solution or some information what could be wrong? regards jt |
2个回答
嗨,
我已经解决了。 使用Mig 2.3,此错误已得到修复。 问候 JT 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi, I have solve it. With Mig 2.3 this error is fixed. regards Jt View solution in original post |
嗨,
我已经解决了。 使用Mig 2.3,此错误已得到修复。 问候 JT 以上来自于谷歌翻译 以下为原文 Hi, I have solve it. With Mig 2.3 this error is fixed. regards Jt |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 03:51 , Processed in 0.680417 second(s), Total 45, Slave 38 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1431
