电子发烧友论坛|
我最近执行了ECalwipe Santization作为降级系统的一部分。
我与我的IT部门合作的一个问题是,我们的McAfee Antivirus导致这个过程花费数小时而不是几分钟(它扫描每次读/写),我最终让它一夜之间运行,因为第一次擦除通过 超过5个小时。 第二天早上,我检查完成了没有错误的清理,验证它仍然被识别,关闭了实用程序并从系统中删除了ECal。 我现在遇到的问题是连接到系统时不再识别ECal。 此外,用于执行清理的系统也被降级并在未分类的程序中使用。 ECalwipe期间存储的Factory Characterization文件在哪里? 我相信我需要将它从分类驱动器复制到PC并使用PC版本恢复ECal,然后再次清理它(因为它将连接到分类PC)。 问题是,如何在断开连接之前验证它是否正常工作,因为它上次似乎没问题。 这是我第一次对ECal进行消毒并且之后尝试使用它,我们通常只在它们进行校准时进行消毒,所以我不知道这是不寻常的。 此外,它在升级之前没有找到我,所以我没有在Unclassified系统上保存的Factory Characterization。 Spacecase 以上来自于谷歌翻译 以下为原文 I recently performed the ECalwipe Santization as part of a downgrading a system. One problem, which I am working with my IT department on, is our McAfee Antivirus caused the process to take hours instead of minutes (it was scanning every read/write), I ended up letting it run overnight, since the first wipe pass took over 5 hours. The next morning I checked that sanitization was complete with no errors, verified that it was still recognized, shut down the utility and removed the ECal from the system. The problem I am having now is the ECal is no longer recognized when connected to a system. Also, the system that was used to perform the sanitization was also downgraded and is in use on an unclassified program. Where is the Factory Characterization file stored during ECalwipe? I believe I need to copy it from the classified drive to a PC and use the PC version to restore the ECal, then sanitize it again (since it will be connected to a classified PC). The question is, how do I verify that it is working correctly before disconnecting it, since it appeared to be OK last time. This is the first time I have sanitized an ECal and tried to use it afterwards, we usually sanitize only when they are due for calibration, so I don't know if this is unusual or not. Also, it did not come to me before being upgraded, so I do not have a saved Factory Characterization on an Unclassified system. Spacecase |
1个回答
从程序附带的文档中:+如果清除过程中断,ECal模块很可能会处于无效状态,并且将不再起作用。
如果发生这种情况,则包括恢复过程。 在擦除ECal内存之前,始终在目录D: Ecal 中创建备份文件(如果D驱动器不可用于写入,则将使用C驱动器。)此备份文件仅包含所需的工厂数据; 没有任何用户信息。 要使用此恢复功能,请仅将非功能性ECal设备连接到PNA并运行该程序。 将检测到错误条件并允许访问恢复功能。 系统将要求您浏览正确的数据文件(保存在ECal模块的型号和序列号下。)恢复大约需要2分钟。+ _如果仍有问题,请告诉我。 jvallEdited:jvall于2012年11月4日上午12:05 以上来自于谷歌翻译 以下为原文 From the documentation that should have accompanied the program: +If the clearing process is interrupted, the ECal module will most likely be left in an invalid state and will no longer be functional. Should this happen, a Recovery process is included. Before erasing the ECal memory, a backup file is always created in the directory D:Ecal (if a D drive is not available for writing, the C drive will be used instead.) This backup file contains only the required factory data; not any user information. To use this recovery feature, connect only the non-functional ECal unit to the PNA and run the program. An error condition will be detected and allow access to the Recovery function. You will be asked to browse to the proper data file (saved under the model number and serial number of the ECal module.) Recovery takes about 2 minutes.+_ If you still have problems, let me know. jvall Edited by: jvall on Nov 4, 2012 12:05 AM |
只有小组成员才能发言,加入小组>>
1842 浏览 0 评论
2738 浏览 1 评论
2640 浏览 1 评论
2447 浏览 5 评论
3452 浏览 3 评论
1843浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 17:46 , Processed in 0.641728 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2085
