电子发烧友论坛|
嗨,
我正在考虑用SPartan 6进行设计。然而,通过LDO提供的平均电流是多少? 它是100ma的量级? 是500ma吗? 以上来自于谷歌翻译 以下为原文 Hi, I am thinking of designing aboard with the SPartan 6. However what is the average current which shoul be supplied via the LDO? Is it of the order of 100ma? Is it 500ma? |
4个回答
@red_ferrari
如果你有设计,你可以使用功率估算器 http://www.xilinx.com/products/technology/power/xpe.html 如果没有,请在下面查看关于相关讨论和建议的链接 https://forums.xilinx.com/t5/Spartan-Family-FPGAs/SPARTAN-6-LXT-Power-Data-maximum-rating/td-p/101046 https://forums.xilinx.com/t5/Spartan-Family-FPGAs/Spartan-6-current-consumption-during-programming/td-p/202591 希望这可以帮助 -Vanitha -------------------------------------------------- -------------------------------------------请在发布前进行谷歌搜索, 您可能会找到相关信息。请留下帖子 - “接受为解决方案”,如果提供的信息有用且回复,请给予赞誉 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 @red_ferrari If you have the deisgn you can use power estimator http://www.xilinx.com/products/technology/power/xpe.html If not please check below links on relavant discussion and suggestions https://forums.xilinx.com/t5/Spartan-Family-FPGAs/SPARTAN-6-LXT-Power-Data-maximum-rating/td-p/101046 https://forums.xilinx.com/t5/Spartan-Family-FPGAs/Spartan-6-current-consumption-during-programming/td-p/202591 Hope this helps -Vanitha --------------------------------------------------------------------------------------------- Please do google search before posting, you may find relavant information. Mark the post - "Accept as solution" and give kudos if information provided is helpful and reply oriented View solution in original post |
@red_ferrari
如果你有设计,你可以使用功率估算器 http://www.xilinx.com/products/technology/power/xpe.html 如果没有,请在下面查看关于相关讨论和建议的链接 https://forums.xilinx.com/t5/Spartan-Family-FPGAs/SPARTAN-6-LXT-Power-Data-maximum-rating/td-p/101046 https://forums.xilinx.com/t5/Spartan-Family-FPGAs/Spartan-6-current-consumption-during-programming/td-p/202591 希望这可以帮助 -Vanitha -------------------------------------------------- -------------------------------------------请在发布前进行谷歌搜索, 您可能会找到相关信息。请留下帖子 - “接受为解决方案”,如果提供的信息有用且回复,请给予赞誉 以上来自于谷歌翻译 以下为原文 @red_ferrari If you have the deisgn you can use power estimator http://www.xilinx.com/products/technology/power/xpe.html If not please check below links on relavant discussion and suggestions https://forums.xilinx.com/t5/Spartan-Family-FPGAs/SPARTAN-6-LXT-Power-Data-maximum-rating/td-p/101046 https://forums.xilinx.com/t5/Spartan-Family-FPGAs/Spartan-6-current-consumption-during-programming/td-p/202591 Hope this helps -Vanitha --------------------------------------------------------------------------------------------- Please do google search before posting, you may find relavant information. Mark the post - "Accept as solution" and give kudos if information provided is helpful and reply oriented |
@red_ferrari说实话,这是一个非常开放的问题,没有答案。
Spartan 6(VCCINT,VCCAUX,VCCO)上有多个电压轨,它们在不同的电压下工作,因此您需要的不仅仅是一个稳压器。 正如vanitha在上面指出的那样,如果你了解你的设计,那么XPE将是一个很好的开始,可以让你得到数字。 也要经历这些线程,这应该可以帮助您获得所需的信息 -------------------------------------------------- -------------------------------------------------- ----------------没有一个愚蠢的问题。 随意问,但快速搜索,以确保它还没有得到解答。 保持对话,获得Kudos和Accept Solution。 -------------------------------------------------- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @red_ferrari To be honest, thats a very open ended question that wouldn't have an answer. There are multiple voltage rails on Spartan 6 ( VCCINT, VCCAUX, VCCO) which operate at different voltages and so you would need more than a single regulator. As vanitha pointed out above, if you know your design, XPE would be a good start to get you the numbers. Do go through those threads as well which should help you get the information you looking for -------------------------------------------------------------------------------------------------------------------- There's no such thing as a stupid question. Feel free to ask but do a quick search to make sure it ain't already answered. Keep conversing, give Kudos and Accept Solution when you get one. ----------------------------------------------------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
3141 浏览 7 评论
3435 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2897 浏览 9 评论
4097 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3082 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1359浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1196浏览 1评论
/9
GMT+8, 2025-12-11 17:21 , Processed in 0.653134 second(s), Total 50, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2803
