电子发烧友论坛|
你好,
本地xilinx.lic在xilinx.lic文件中有Xilinx_AXI_BFM的条目; 当我运行licesne manager时,它只显示Analyzer(一旦Xilinx支持人员说这是报告问题) 无论如何,当我运行modelsim得到 BFM Xilinx:Xilinx_AXI_BFM版本2010.100000的许可证失败 任何帮助? 问候,弗雷德 以上来自于谷歌翻译 以下为原文 Hello, The local xilinx.lic has the entry for Xilinx_AXI_BFM in xilinx.lic file; When I run licesne manager it only shows Analyzer (once a Xilinx support guy said it is the reporting issue) Anyway when I run modelsim getting BFM Xilinx: License failed for Xilinx_AXI_BFM, version 2010.100000 any help? Regards, Fred |
4个回答
嗨@ fsahebi2014
你能否附上你的许可证文件& 信佛? 谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi @fsahebi2014 Can you please attach your license file & xinfo? Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
检查这些AR
http://www.xilinx.com/support/answers/61473.html http://www.xilinx.com/support/answers/62030.html http://www.xilinx.com/support/answers/63841.html 谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 check these ARs http://www.xilinx.com/support/answers/61473.html http://www.xilinx.com/support/answers/62030.html http://www.xilinx.com/support/answers/63841.html Thanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
是的,AXI_BFM需要许可证。
这是ISE还是Vivado? 当然,如果.lic拥有它,许可证管理器应该显示AXI_BFM许可证。 我会确保再次设置许可证,关闭Vivado并再次打开它并检查许可证管理器。 还要确保版本限制正确,以用于该版本的Vivado / ISE。 谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Yes, AXI_BFM needs a license. Is this ISE or Vivado? Sure, the license manager should show the AXI_BFM license if the .lic has it. I would make sure to set the license again, close the Vivado and open it again and check in the License manager. Also make sure the version limit is correct to be used for that version of Vivado/ISE.Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution. |
嗨弗雷德,
您似乎拥有所需的许可证功能。 你能检查许可证是否安装正确吗? 您还使用哪个版本的工具? 您可以复制粘贴许可证文件中的相应部分吗? 问候 Sikta 以上来自于谷歌翻译 以下为原文 Hi Fred, It seems that you have the needed license feature. Can you check if the license is installed properly? Also which version of tools are you using? Can you copy paste the corresponding section from the license file? Regards Sikta |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 02:46 , Processed in 0.664602 second(s), Total 48, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3000
