电子发烧友论坛|
有一天,我能够在Questasim中检索XILINX_AXI_BFM许可证,第二天它失败并且从那时起失败了。
许可证服务器已重置但仍然失败... 有任何想法吗? #BFM Xilinx:Xilinx_AXI_BFM版本2010.100000的许可证成功 然后一天后 #BFM Xilinx:Xilinx_AXI_BFM版本2010.100000的许可证失败 谢谢 蒂姆 以上来自于谷歌翻译 以下为原文 One day I was able to retrieve the XILINX_AXI_BFM license in Questasim, and the next day it fails and has failed since. License servers have been reset and still fails... Any ideas? # BFM Xilinx: License succeeded for Xilinx_AXI_BFM, version 2010.100000 Then one day later # BFM Xilinx: License failed for Xilinx_AXI_BFM, version 2010.100000 Thanks Tim |
3个回答
嗨,
在此处附加xinfo文件以调试问题。 谢谢 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, Attach your xinfo file here to debug the issue. Thanks -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
看起来我的IT部门最终确信我们拥有该功能,并且它实际上位于另一个位置的服务器上。
它现在在哪里,我们不知道.......感谢您的回应 以上来自于谷歌翻译 以下为原文 Looks like my IT department finally is convinced we have that feature and it WAS actually located on a server in another location. Where it is now, we don't know....... Thanks for the response nonetheless |
嗨,请将您的帖子标记为“接受为解决方案”谢谢
-------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, Mark your post as "Accept as Solution" Thanks-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 23:55 , Processed in 0.774838 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1938
