Windows 7 64 68013A 128引脚上没有EEPROM CysB.SIS和CysB.INF,INC和LIB文件的自定义板来自CySudio3.4.6
该板使用VID/PID 04B4/8613枚举为“CyPress EZ-USB FX2LP—EEPROM遗失”。 一个使用GPIF示例的OLDBult/FIFO构建并使用KEIL UV2和EZ-USB接口(1.7.0.2)成功下载 一旦下载,它将重新枚举显示“CyPress USB通用驱动程序”在“设备管理器”,但停止了一个代码10错误,使其不可用CySuto等。 它与以前的CysB.SIS驱动程序(04B4/1004)一起工作在XP/32中,这与W-7/64不起作用。 我花了很多时间寻找一个相似的帖子,如果它是一个,就错过了。如有任何建议,将不胜感激。 以下是Keil UV2构建和INF文件的片段: DSC.A51 DeCIEDSCR:DW 0B404H;供应商ID DW01486H;产品ID/DW 01386H;产品ID i包括1004 CysB.Inf;用于X64平台[设备.NTAMD64 ];用于X64平台[设备.NIDAMD64 ] %VIDY04B4&PIDY8613. DeVice DISC%= CYUSB,USB VIDY04B4&PIDY8613%VIDU04B4&PIDY8614 . DeVice DISC%= CYUSB,USB VIDY04B4和PIDY8614 对于X64平台[设备.NTAMD64 ] VIDU04B4&PIDY8613.DEVICESDESC=“CyPress EZ-USB FX2LP -EEPROM遗失”VIDA04B4&PIDY8614.DEVICESDESC =“CyPress USB通用驱动程序(3.4.6000)” 以上来自于百度翻译 以下为原文 Windows 7 64 68013a 128 pin on a custom board with no eeprom CYUSB.sys and CYUSB.inf, INC and LIB files are from CyConsole 3.4.6 The board enumerates using vid/pid 04b4 / 8613 as "Cypress EZ-USB FX2LP - EEPROM missing" A old bulk/fifo with gpif example builds and successfully downloads using Keil UV2 and EZ-USB Interface (1.7.0.2) Once downloaded it will re-enumerate showing "Cypress USB Generic Driver " in the Device Manager" but is stopped with a code10 error making it unavailable to CyConsole etc. It worked with with the previous cyu***.sys driver (04B4 / 1004) in XP/32 which does not work with W-7 / 64 I've spent a lot of time searching for a similar post and missed it if this is one. Any suggestions will be appreciated. Here are snippets from the Keil UV2 build and inf files: dscr.a51 DeviceDscr: dw 0B404H ; Vendor ID dw 01486H ; Product ID // dw 01386H ; Product ID I have tried all 3 including pid 1004 cyu***.inf ;for x64 platforms [Device.NTamd64] ;for x64 platforms [Device.NTamd64] %VID_04B4&PID_8613.DeviceDesc%=CyU***, USBVID_04B4&PID_8613 %VID_04B4&PID_8614.DeviceDesc%=CyU***, USBVID_04B4&PID_8614 [Strings];for x64 platforms [Device.NTamd64] VID_04B4&PID_8613.DeviceDesc="Cypress EZ-USB FX2LP - EEPROM missing" VID_04B4&PID_8614.DeviceDesc="Cypress USB Generic Driver (3.4.6.000)" |
1个回答
如果您右键单击设备管理器中的设备,那么执行更新驱动程序并指向该INF文件的位置。您得到的错误消息是什么??
当做, 阿南德 以上来自于百度翻译 以下为原文 If you right click the device in device manager then do a update driver and point to the location of this inf file what is the error message you get?? Regards, Anand |
只有小组成员才能发言,加入小组>>
742个成员聚集在这个小组
加入小组2012 浏览 1 评论
1773 浏览 1 评论
3563 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1705 浏览 6 评论
1473 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
370浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
261浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
364浏览 2评论
304浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
503浏览 2评论
GMT+8, 2024-9-30 05:21 , Processed in 0.716663 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
