电子发烧友论坛|
我昨天拿到了N9923A。
我必须承认,我对这样一个小盒子能做的事情印象深刻。 我注意到N9923A支持多种校准套件,包括我所拥有的N型85032B型。 我认为它也可能支持我的3.5毫米校准套件。 但是有可能支持用户定义的校准套件,其中输入偏移的是ps和电容系数C0,C1,C2和C3吗? 如果是这样的话,人们在哪里这样做,因为我似乎无法在菜单上找到它,尽管我只用它“玩”了一个小时左右。 我不知道我的固件版本,但鉴于它是在一周前从安捷伦发货的,我希望它是最新的。 该手册共139页,比我8720D上的文档阅读轻松得多! DaveEdited:drkirkby于2012年10月5日上午8:11 以上来自于谷歌翻译 以下为原文 I got my N9923A yesterday. I must admit I'm quite impressed with what such a small box can do. I noticed the N9923A supports several calibration kits, including the type-N 85032B that I have. I think it might also support my 3.5 mm calibration kit. But is it possible to support a user-defined cal kit, where one enters the offsets is ps and capacitance coefficients C0, C1, C2 and C3? If so, where does one do this, as I can't seem to find it on the menus, though I've only "played" with it for an hour or so. I don't know my firmware version off-hand, but given it was shipped from Agilent only a week ago, I would expect it is up to date. The manual, at 139 pages, is a much lighter read than the documentation on my 8720D! Dave Edited by: drkirkby on Oct 5, 2012 8:11 AM |
2个回答
快速答复是的。
寻找数据链接软件。 请访问www.agilent.com/find/fieldfoxsupport使用Data Link,您可以创建一个校准套件文件并将其加载到N9923A中。 #cal kit没有限制。 数据链接有自己的帮助系统。 关于ver kit的另一个问题,我们还没有要求R& D添加它。 可能可以通过一些未来的修订来完成。 您的固件可能是A.05.53或类似的东西。 如果您在我们的网站上看到A.06.02,请不要升级到它,因为它不适用于Data Link。 他们很快就会同步,但是现在,请继续使用你的A.05.53。 Afsi 以上来自于谷歌翻译 以下为原文 A quick reply of yes. Look for the Data Link software. Try www.agilent.com/find/fieldfoxsupport Using Data Link, you can create a cal kit file and load it into the N9923A. No limit on the # cal kits. Data link has it's own help system. On your other question of ver kit, just haven't gotten to asking R&D to add it. Probably can be done with some future revision. Your firmware is probably A.05.53 or something similar. If you see an A.06.02 on our website, don't upgrade to it yet as it doesn't work with Data Link. They'll be sync'd up soon, but for now, stay with your A.05.53. Afsi |
dsgdadsad 发表于 2019-3-22 18:24 > {quote:title = am95405写道:} {quote}>快速答复是的。 寻找数据链接软件。 请访问www.agilent.com/find/fieldfoxsupport >>使用数据链接,您可以创建一个校准套件文件并将其加载到N9923A中。 #cal kit没有限制。 数据链接有自己的帮助系统。 很棒,虽然看起来我的N9923A附带的固件(A.06.02)不适用于Data Link。 我有N(85032B)和3.5毫米(85033E)校准套件的固件直接支持,但我想添加对另一个N cal套件的支持。 >关于ver kit的另一个问题,我们还没有要求R& D添加它。 可能可以通过一些未来的修订来完成。 如果可以,我们将不胜感激。 我认为N验证套件仅支持85032F和非常昂贵的85054B,但是至少在N9923A中内置的套件中添加固件支持会很好。 有人很可能购买T或4合1套件,因此用它们验证性能的能力可能非常有用 - 当然我想支持旧的85032B! >您的固件可能是A.05.53或类似的东西。 如果您在我们的网站上看到A.06.02,请不要升级到它,因为它不适用于Data Link。 他们很快就会同步,但是现在,请继续使用你的A.05.53。 我刚刚检查过它 - 它随A.06.02一起发货。 我现在不打扰,但我认为固件版本可能会降级,因此数据链接将起作用。 但至少现在,我有很多东西可以学习这个工具。 > Afsi谢谢你Afsi。 DaveEdited:drkirkby于2012年10月5日上午10:58 以上来自于谷歌翻译 以下为原文 > {quote:title=am95405 wrote:}{quote} > A quick reply of yes. Look for the Data Link software. Try www.agilent.com/find/fieldfoxsupport > > Using Data Link, you can create a cal kit file and load it into the N9923A. No limit on the # cal kits. Data link has it's own help system. Great, although it looks like the firmware (A.06.02) which was shipped with my N9923A will not work with Data Link. There is direct support in firmware for the N (85032B) and 3.5 mm (85033E) cal kits I have, but I'd like to add support for another N cal kit. > On your other question of ver kit, just haven't gotten to asking R&D to add it. Probably can be done with some future revision. If you could, it would be appreciated. I think the N verification kit is only supported with the 85032F and the very expensive 85054B, but adding support in firmware for at least the kits built in the N9923A would be good. Someone is quite likely to buy a T or 4-in-1 kit, and so the ability to verify the performance with them could be very useful - and of course I'd like support for the older 85032B! > Your firmware is probably A.05.53 or something similar. If you see an A.06.02 on our website, don't upgrade to it yet as it doesn't work with Data Link. They'll be sync'd up soon, but for now, stay with your A.05.53. Em, I just checked - it was shipped with A.06.02. I wont bother now, but I assume the firmware version could be downgraded so Data Link will work. But for now at least, I have plenty to learn about this tool. > Afsi Thank you Afsi. Dave Edited by: drkirkby on Oct 5, 2012 10:58 AM |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 22:47 , Processed in 1.134990 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2664
