扫一扫,分享给好友
嗨,
我试过安装Vivado(2014.2或2014.3,同样的问题),我只是我电脑的用户。 安装程序需要管理员权限。 我知道密码并且它没问题但是在安装之后用户没有任何快捷方式或图标来运行Vivado。 我不得不手动将快捷方式从管理员文件夹复制到用户文件夹。 为什么不由安装人员自动完成? 以上来自于谷歌翻译 以下为原文 Hi, I've tried to install Vivado (2014.2 or 2014.3, same problem) and I'm only a user of my computer. The installer need administrator privileges. I know the password and it went OK but after the installation the user doesn't have any shortcut or icon to run Vivado. I had to manually copy the shortcut from the administrator folder to the user one. Why is it not done automaticaly by the installer? |
3个回答
你好,
您在以下安装屏幕中选择了什么选项(安装Vivado时)? 我想你选择了当前用户。 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hello, What option did you select in the below installation screen (while installing Vivado)? I think you had selected Current User. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution.View solution in original post |
你好,
您在以下安装屏幕中选择了什么选项(安装Vivado时)? 我想你选择了当前用户。 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hello, What option did you select in the below installation screen (while installing Vivado)? I think you had selected Current User. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
由于我的屏幕分辨率,我没有看到此选项。
谢谢。 以上来自于谷歌翻译 以下为原文 I didn't see this option because of my screen resolution. Thanks. |
只有小组成员才能发言,加入小组>>
2427 浏览 7 评论
2828 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2295 浏览 9 评论
3377 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2467 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
1271浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
592浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
455浏览 1评论
2010浏览 0评论
736浏览 0评论
GMT+8, 2024-12-26 09:15 , Processed in 1.209320 second(s), Total 49, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
