先生/女士,
我们如何从virtex 5(XC5VLX110T)获取时钟信号? 我们已经参考了用户手册并尝试从d手册中提到的几个引脚获取信号。 针脚:AH17,AG18。 通过AH17引脚的输出是17 MHz三角波,假设是33MHz方波,而从AG18,输出是27 MHz三角波而不是27 MHz方波。 那么我们怎么能得到预期的方波? 以上来自于谷歌翻译 以下为原文 Sir/Madam, How can we get clock signal from virtex 5(XC5VLX110T)?? We have referred the user manual and tried getting signal from several pins that were mentioned in d manual. pins : AH17, AG18. The output through AH17 pin is 17 MHz triangular wave, which was supposed to be 33MHz square wave and from AG18, the output is 27 MHz triangular wave instead of 27MHz square wave. So how can we get the expected square wave?? |
4个回答
你是怎么把时钟赶走的?
你如何验证时钟波形? ----------“我们必须学会做的事情,我们从实践中学习。” - 亚里士多德 以上来自于谷歌翻译 以下为原文 How are you trying to drive the clock out? How are you verifying the clock waveform? ---------- "That which we must learn to do, we learn by doing." - Aristotle |
代码是检查时钟。
在架构中我们写了“c 7 MHz时钟”,'c'分配给H34(J6上的引脚6)。 我们观察到H34到DSO的输出是一个27MHz的三角波而不是方波。 以上来自于谷歌翻译 以下为原文 The code is to check the clock. In architecture we wrote " c <= a; " where 'a' is assigned to AG18( 27 MHz clock) and 'c' is assigned to H34(pin 6 on J6). We observed the output from H34 through DSO which was a triangular wave of 27MHz instead of square wave. |
我对Virtex 5时钟技术并不太熟悉,但我认为您应该查找“Xilinx FPGA中的时钟转发”。
我不认为你可以简单地将一个全局时钟分配给一个没有调节的外部引脚。 此外,您的“范围”如何设置? 你使用什么类型的探头? '范围交流或直流耦合? ----------“我们必须学会做的事情,我们从实践中学习。” - 亚里士多德 以上来自于谷歌翻译 以下为原文 I am not too familiar with the Virtex 5 clocking technology but I think you should probably look up "clock forwarding in Xilinx FPGAs". I don't think you can simply assign a global clock to an external pin with no conditioning. Additionally, how is your 'scope set up? What type of probe are you using? Is the 'scope AC or DC coupled? ---------- "That which we must learn to do, we learn by doing." - Aristotle |
数字IO不能输出非矩形波形。
如果您看到三角波,则无论是与引脚的连接还是用于测量信号的设备都存在问题。 三角波将是带限方波的表示。 确认您的测量设备支持带宽,并且您没有驱动大负载或者电线过长或接地返回。 马克。 以上来自于谷歌翻译 以下为原文 Digital IOs cannot output non rectangular waveforms. If you are seeing a triangular wave, there's an issue with either the connection to the pin or the device you are using to measure the signal. A triangular wave will be a representation of a band-limited square wave. Verify that your measuring device supports the bandwith and that you are not driving a large load or have excessively long wires or ground return. Marc. |
只有小组成员才能发言,加入小组>>
2215 浏览 7 评论
2640 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2119 浏览 9 评论
3188 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2243 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
491浏览 1评论
1570浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2217浏览 0评论
543浏览 0评论
1704浏览 0评论
GMT+8, 2024-6-26 18:16 , Processed in 1.196186 second(s), Total 54, Slave 48 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
