电子发烧友论坛|
你好,
我想问一下不同7系列家族(Virtex7,Artix7,Kintex7,Zynq7)之间的差异。 据我所知,所有7Series设备或多或少共享相同的架构,我不是这个主题的专家,但我到目前为止所拥有的内容结构与DSP宽度,LUT的宽度,时钟分配资源相同 等等...因此,尽管所有这些不同系列(Zynq的处理核心除外)的唯一区别是它们的最小/最大可用尺寸以及Easypath产品的选项。 但是我在许多IP内核数据表中看到,最大可达频率通常会在不同系列之间发生变化(virtex通常是最快的)。 怎么来的? 他们毕竟不是共享相同的架构,还是可以购买不同的速度等级? 此外,我想询问新的Zynq设备是否可以购买,如果没有,预计它们何时会出现。 我咨询过我惯常的问题,他们现在似乎没有任何库存。 谢谢! 以上来自于谷歌翻译 以下为原文 Hello, I wanted to ask something about the differences among different 7Series families (Virtex7, Artix7, Kintex7, Zynq7). As I understand all 7Series devices share the same architecture more or less, I am not an expert in this topic but what I had though until now is that they all had the same internal structure as far as DSP widths, LUT's width, clock distribution resources etc... Therefore I though the only difference among all these different families (with the exception of Zynq's processing core) was their minimum/maximum available sizes and the option for the Easypath products. However I have seen in many IP cores datasheet's that the maximum frequency reachable usually changes among different families (virtex usually beeing the fastest). How come? Do they not share the same architecture after all or is this a matter of the different speed-grades available for purchase? Also, I wanted to ask if the new Zynq devices are available for purchase and if not, when is it expected that they will be. I have consulted my usual probiders and they don't seem to have any of them in stock for now. Thanks! |
1个回答
虽然家庭之间存在显着的相似性,但也存在差异。
Artix-7系列支持更宽的电压范围,因此性能更低。 Artix-7和Kintex-7系列还具有较低的成本/性能包,这将影响IO接口的性能。是的,Zynq设备正在生产和可用。 ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 While there is significant similarity between families there are also differences. The Artix-7 family supports a wider voltage range and as a result has a lower performance. The Artix-7 and Kintex-7 families also have lower cost/performance packages which will impact the performance for IO interfaces. Yes, Zynq devices are in production and avaialable.------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 04:20 , Processed in 0.598931 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1498
