电子发烧友论坛|
对ST加速度计来说,我可以看到它们被分为三个“家族” - 纳米,微微和毫微微。这三个家庭之间的差异是否有简短的解释?链接到一个页面解释,这将是困难,谢谢。
rday 以上来自于谷歌翻译 以下为原文 Totally new to ST accelerometers, I can see that they're grouped into what look like three 'families' -- nano, pico and femto. Is there a short explanation of the differences between those three families? A link to a page explaining that would be just ducky, thanks. rday |
2个回答
我认为,这些都是更多的营销术语。
我宁愿使用以下矩阵代替。 也可以找到产品选择器 http://www.st.com/en/mems-and-sensors/accelerometers.html?querycriteria=productId=SC444 。 以上来自于谷歌翻译 以下为原文 I think, these are more marketing terms. I would rather use following matrix instead. Product selector can be find also http://www.st.com/en/mems-and-sensors/accelerometers.html?querycriteria=productId=SC444 . |
如果它们只是营销术语,那么产品摘要表似乎有点混淆似乎强调分类如此突出。如果我看一下LIS2DW12的页面,
http://www.st.com/content/st_com/en/products/mems-and-sensors/accelerometers/lis2dw12.html ,我在前几行告诉我这个项目是'femto'家族的成员。但是如果没有对这意味着什么的定义,那么告诉我信息是无用的甚至是混乱的,因为我读到的第一件事就是“'femto'是什么意思?我应该已经明白了吗?有没有解释它的词汇表? 'femto'比'pico'更好吗?'除非有一页解释了这些家庭之间的差异,否则提及它绝对没有营销价值。 以上来自于谷歌翻译 以下为原文 If they're just marketing terms, then it's a bit confusing for the product summary sheet to seem to emphasize that categorization so prominently. If I look at, say, the page for the LIS2DW12, http://www.st.com/content/st_com/en/products/mems-and-sensors/accelerometers/lis2dw12.html , I am told in the first few lines that this item is a member of the 'femto' family. But without a definition of what that means, then telling me that information is useless and even confusing, since the first thing I thought of when I read that is, 'What does 'femto' mean? Am I supposed to already understand that? Is there a glossary that explains it? Is 'femto' better than 'pico'?'Unless there's a page that explains the difference between those families, there's absolutely no marketing value in mentioning it. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1472 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1524 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3674 浏览 1 评论
3864 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2483 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
751浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
684浏览 5评论
730浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
974浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
779浏览 5评论
/9
GMT+8, 2025-12-14 07:51 , Processed in 0.496105 second(s), Total 44, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
500
