电子发烧友论坛|
您好安捷伦用户,我已经阅读了34972A的手册,您可以从设备上FTP数据文件。
我试图用一些不同的方法匿名登录,只是为了让我的“连接被拒绝”。 我试过从Windows XP命令行,Mac OSX命令行和filezilla ...我不知道我在这里缺少什么...数据记录器中是否有关闭FTP访问的设置? 手册中的页面是174 ...手册位于:http://cp.literature.agilent.com/litweb/pdf/34972-90001.pdf ...我将固件从1.12更新到1.16但仍然没有。 ..任何帮助表示赞赏...谢谢,WillEdited:wbfranklin于2014年1月2日上午10:56 以上来自于谷歌翻译 以下为原文 Hello fellow Agilent users, I've read in the manual for the 34972A that you can FTP the data files from the unit. I've tried to log in as anonymous with a few different methods only to have my "connection refused". I've tried from windows XP command line, Mac OSX command line, and filezilla… I'm not sure what I'm missing here… Is there a setting within the Datalogger that turns off FTP access?? The page in the manual is 174… The manual is located here: http://cp.literature.agilent.com/litweb/pdf/34972-90001.pdf …and I updated the firmware from 1.12 to 1.16 and still no go... Any help is appreciated… Thanks, Will Edited by: wbfranklin on Jan 2, 2014 10:56 AM |
1个回答
*来自安捷伦技术支持:* * ======================== *您好,感谢您与安捷伦科技公司联系。
如果您有更新版本的固件,则问题可能是FTP被禁用。 在较新版本的固件上,这是默认设置。 尝试发送(使用Agilent Interactive IO / Agilent Connection Expert)*“DIAG:SEC FTP,ON”*命令,然后重复本手册中的步骤。 它应该接受此时的连接。 * ======================== *通过Interactive IO发送该命令就可以了! 感谢所有回复的人! 一切顺利,威尔 以上来自于谷歌翻译 以下为原文 *From Agilent Technical Support:* *========================* Hi Will, Thanks for contacting Agilent Technologies. If you have a newer version of firmware your problem may be that the FTP is disabled. On newer versions of firmware, this is the default. Try sending a (with the Agilent Interactive IO/Agilent Connection Expert) *“DIAG:SEC FTP,ON”* command and then repeating the steps in the manual. It should accept the connection at this point. *========================* Sending that command through the Interactive IO did the trick! Thanks to all who replied! All the best, Will |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 23:46 , Processed in 0.814552 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2038
