你好,
我正在评估L6470作为已停产芯片的替代品,目前已在我们的应用中使用。 我必须达到高速(2500步/秒),但是当超过800步/秒时,电机会失步。以下是我的电机特性:根据数据表: Rm = 0,8欧姆 Lm = 1 mH (我测量的Rm = 3,3欧姆; Lm = 5.3 mH) ke = 0,115 V / Hz 我用的是24V电源。 我用dSPIN评估工具尝试了很多不同的参数,但800步/秒似乎是上限,尽管旧的电机驱动器很容易达到2500步/秒。 有人对我有暗示吗? 顺便说一下,我正在评估EVAL6470H板。 问候, 斯特凡 以上来自于谷歌翻译 以下为原文 Hello, I am evaluating the L6470 as replacement for a discontinued chip, which is used in our application in the moment. I have to reach high speed (2500 step/s), however when going above 800 step/s the motor looses steps. Here are my motor characteristics: according to datasheet: Rm = 0,8 Ohm Lm = 1 mH (I measured Rm = 3,3 Ohm; Lm = 5,3 mH) ke = 0,115 V/Hz I use 24V power supply. I tried a lot of different parameters with dSPIN Evaluation tool, but 800 step/s seems to be the upper limit, although the old motor driver reaches 2500 step/s easily. Does anyone have a hint for me? BTW, I'm evaluating with EVAL6470H board. regards, Stefan |
3个回答
你好Stefan,
这个问题可能与电机的中速共振有关。如果电机卸载,我建议你在轴上加一个小负载(例如加几圈胶带),这样谐振应该稍微减弱,避免步进损失。 BR 恩里科 以上来自于谷歌翻译 以下为原文 Hello Stefan, the issue is probably related to the mid-speed resonance of the motor. If the motor is unloaded I suggest you to add a small load on the shaft (e.g. adding few rounds of adhesive tape), this way the resonance should be dampen a bit and the step-loss is avoided. BR Enrico |
嗨,恩里科,
谢谢你的快速回复。无论有无负载,我都试过了,但没有区别。我看了一下示波器,发现当前的峰值不在步骤的中心(见附件)这是正常的吗?如果没有,哪个参数改变了这种行为? 以上来自于谷歌翻译 以下为原文 Hi, Enrico, thanks for your fast reply. I tried both, with and without load, but there is no difference. I took a look at the oscilloscope and found that the current peak is not in the center of the step (see attached file) Is that normal? If not, which parameter changes this behavior? |
嗨Stefan,
输出电压和电机电流之间的相位关系取决于电机的电气特性和机械负载,因此波形正常。 你试着增加电机电流吗?也许仅保持电机以该速度运转是不够的。 问候 恩里科 以上来自于谷歌翻译 以下为原文 Hi Stefan, The phase relation between the output voltage and the motor current depends on the electrical characteristics of the motor and the mechanical load, so the waveforms are ok. Did you try to increase the motor current? Maybe it is not enough to keep the motor running at that speed. Regards Enrico |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 07:01 , Processed in 0.624690 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2072
