电子发烧友论坛|
通过“超速装置-设计示例”,在C.4示例7中,提到了柏树的钩子与线程/信号量等有关。指示何时发生变化,以便工程师可以实时地在GPIO管脚上用逻辑分析仪监控这种序列。
在PG.78的书中有一句话:“在我的请求下,CyPress增加了一个RTOS内核钩子,当它启动一个新的线程时,当这个线程挂起时通知我们。在示例7的PrruleDebug的Mag文件中,有一条线调用GCC编译器,其中的参数指向“……CyPress EZ-USB FX3SDK 1.3 固件/U3Py固件/LIB/FX3PrPrIORIDEBUG/CUU3LPP。”(和其他类似的)。 但是,在我完全安装FX3SDK时,在…固件/U3Py固件/LIB/文件夹中,只有两种LIBS的变体:FX3Y调试和FX3X版本;没有FX3SPLORILY调试的标志!! 请问我从哪里可以得到FX3库的“启用配置文件”? 谢谢您。 以上来自于百度翻译 以下为原文 Working through the book "SuperSpeed Device - Design by Example", at the Ch.4 Example 7 there is mention of hooks from Cypress in regard with threads/semaphores/etc.. indicating when changes occurs, so that the Engineer can monitor with a Logic Analyzer on GPIO pins such sequences, in Real-Time. There is a phrase in the book at pg.87: "At my request, Cypress have added an RTOS kernel hook that informs us when it starts up a new thread and when this thread suspends". Looking in the ProfileDebug's makefile of the Example 7, there is a line there that calls the gcc compiler, with parameters pointing to "...CypressEZ-USB FX3 SDK1.3firmware/u3p_firmware/lib/fx3_profile_debug/cyu3lpp.a" (and others like that). However, in my full-install of the FX3 SDK, in the ...firmware/u3p_firmware/lib/ folder there are just two variants of those libs: fx3_debug and fx3_release; no sign of the fx3_profile_debug !!. From where can I get those "Profiling enabled" build of the FX3 libraries, please ? Thank you. |
2个回答
嗨,Dragos,
请从下面的链接下载最新版本的SDK v1.3.3 FX3: http://www.cypress.com/documentation/software-and-drivers/ez-u***-fx3-software-development-kit 在这个SDK中,您可以找到FX3PrPrimeU.Debug。 当做, 拉古兰 以上来自于百度翻译 以下为原文 Hi Dragos, Could you please download the latest version of the FX3 SDK v1.3.3 from the following link: http://www.cypress.com/documentation/software-and-drivers/ez-u***-fx3-software-development-kit In this SDK, you can find fx3_profile_debug. Regards, Raghuram |
我遇到一个问题来创建一个支持我的固件的配置文件。链接FX3PrruleLin库是不够的,因为在启用配置文件时THEXX结构具有不同的定义。
确保在项目中定义CYU3PYPrROLILIN预处理器符号。 当做 以上来自于百度翻译 以下为原文 I run into an issue to create a profiling enabled build of my firmware. Linking the fx3 profiling library is not enough as the ThreadX structures have a different definition when profiling is enabled. Make sure that CYU3P_PROFILE_EN preprocessor symbol is defined in your project. Regards |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-1 22:33 , Processed in 0.653110 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3053
