我已经安装了PSoC Creator和Bootloader应用程序Bootloader。为了部署产品,我需要这个应用程序在没有完全安装PSoC Creator的情况下工作。这是可能的还是我必须自己制作应用程序?
以上来自于百度翻译 以下为原文 I have installed PSoC Creator and the bootloader app bootloader_host.exe work fine. To deploy the product I need this app to work without a full installation of PSoC Creator. Is this possible or do I have to make my own App? |
15个回答
Bootloader应用笔记将很快在Web上发布。
以上来自于百度翻译 以下为原文 The Bootloader Application Note will be made available anytime soon on the web. |
目前Bootloader应用程序与PSoC Creator安装捆绑在一起。它不能作为独立的GUI运行。但是,您可以创建自己的Bootloader应用程序,可以独立运行。讨论的应用注意事项将很快得到。
以上来自于百度翻译 以下为原文 Currently the Bootloader App comes bundled with PSoC Creator installation. It can not run as a stand alone GUI. However, you can create your own Bootloader App that can run stand alone. An Application Note that discusses the same will be available soon. |
很快意味着什么?三个月后仍无应用笔记原来我可以找到。如果柏不会支持要求的功能,你应该这样说,那么我们可以改变的部分,提供我们需要的功能。说什么将“很快”,并没有提供这意味着在未来的赛普拉斯将在未来优先供应商名单低。
以上来自于百度翻译 以下为原文 What does soon mean? Three months since orginal post - still no app note I can find. If Cypress are not going to support required function you should say so then we can change to parts that provide the features we need. Saying something will be available "soon" and then not providing it means that in future Cypress will be low on the list of preferred supplier in the future. |
我们开发了一个USB引导加载程序,它提供了一个GUI,可以用来通过USB引导PSoC3/PSoC5设备。PSoC3设备为此使用HID驱动程序,不需要任何额外的驱动程序。我附上了USB Bootloader GUI的源代码和这里的APP注释DRAFCT的初步版本。这个应用笔记将很快在PSoC3应用笔记页上使用,直到你可以使用这个文档和在Windows XP 32位和Windows 7位32上测试的GUI。
以上来自于百度翻译 以下为原文 We have developed a USB Bootloader solution that provides a GUI that can be used to Bootload PSoC3/PSoC5 device via USB. PSoC3 device uses HID driver for this purpose and it does not need any additional driver. I have attached the source code of the USB Bootloader GUI and a prelimnary version of the App Note drafct here. This App Note will be availabe soon on the PSoC3 App Note page, until then you can use this document and the GUI that is tested work on Windows XP 32 bit and Windows 7 32 bit. |
这里附有基于C的GUI的源代码。它是使用Visual Studio 2008开发的。GUI的可执行文件可以在“UBSBooBooLoultUbjBooLooultbin 调试”或“UBSBooBooLoultUbSoBooLoultbin”版本中找到。
以上来自于百度翻译 以下为原文 The source code for the C# based GUI is attached here. It was developed using Visual Studio 2008. The executable for the GUI can be found in "USB_BootloaderUSB_BootloaderbinDebug" or "USB_BootloaderUSB_BootloaderbinRelease". |
你好,
我正在尝试使用你的应用程序笔记来实现PSoC USB引导加载程序和BootloadBootloader,但是我总是在引导加载主机上出错。 “Bootloader报告错误”Flash行无效,对于所选数组无效 我确信我遵循了双方的指示,我是否漏掉了什么? 我希望我能得到一些帮助来快速解决这个问题,我的产品发货日期也即将到来。 蒂亚 拉里 2011-1130174617JPG 44.6 K 以上来自于百度翻译 以下为原文 Hi, I am attempting to implement a PSOC USB bootloader & bootloadable using your app note but I keep getting an error on the bootloader host: "The bootloader reported error 'The flash row is not valid is not valid for the selected array' I'm certain that I followed the instructions for building both sides, am I missing something? I'm hoping I can get some help to resolve this quickly, my product ship date is coming up (too) soon. TIA, -Larry
我认为最快的方法是用柏树创建一个支持案例并上传他们测试项目。
以上来自于百度翻译 以下为原文 I think the quickest way is to create a support case with cypress and upload the project for them to test. |
我已经附加了Bootloader和使用PSoC C造饰器1构建的BootloadProject。我在这里还附加了一个自定义引导加载程序主机。
如果有任何问题继续存在,让我们知道或提出一个案例与CyPress CRM支持,使问题得到解决。 以上来自于百度翻译 以下为原文 I have attached the Bootloader and the Bootloadable project that is built using PSoC Creator 1.0 . I have also attached a custom Bootloader host here. If any issue continues to exist let us know or raise a case with Cypress CRM support to get the issue resolved. |
谢谢,我开了一个箱子。
我实际上使用的USB引导加载程序,我相信我发现这个线程,大约1 - 2个星期前-除非我没有在正确的地方看,我没有看到一个附加到这个线程现在-我所看到的是一个。 不管怎样,我用CY8C3666 AXI-040(ES2)在CY8CITK-01上运行。 以上来自于百度翻译 以下为原文 Thanks, I have opened a case. I'm actually using the USB Bootloader project that I believe I found on this thread, about 1 -2 weeks ago - unless I'm not looking in the right place I don't see one attached to this thread now - all I see is a .pdf. Anyway, I'm running this on the CY8CKit-001 with a CY8C3866AXI-040 (ES2). |
在这里附加Bootloader项目和应用程序。
引导加载程序 1.4兆字节 以上来自于百度翻译 以下为原文 Attaching the Bootloader project and Application here.
感谢您的帮助,我能够让这个例子工作,现在可以自定义我的应用程序。
以上来自于百度翻译 以下为原文 Thanks for your help, I was able to get the example working and can now customize for my application. |
我很高兴它有帮助。请让我知道,如果你有任何建议或反馈或任何你想看到的USB引导加载应用程序。
以上来自于百度翻译 以下为原文 I am glad that it helped. Please let me know if you have any suggestions or feedback or anything that you would like to see in the USB Bootloader Application. |
你好,
我们目前正在尝试使用文档69848的指令来构建可引导加载的应用程序。 到目前为止,PSoC Creator的部分工作完美,你的C例子做的工作很好。 但是,为了定制我们需要的C语言工具,我们试图自己构建一个IT,但是还不能使它运行。 请您再附上您的范例源代码好吗?似乎是以前发布的,但不知何故后来被删除了。 谢谢。 以上来自于百度翻译 以下为原文 Hi, We are currently trying to build a bootloadable application with the instructions of document 69848. So far, the PSoC Creator part works perfectly and your c# example does the job fine. But in order to customize the c# tool to our needs, we try to build a it on our own, but were not able to get it running yet. Can you please attach your example source code here again? Seems like it was posted before, but somehow was removed later. Thanks. |
我们将很快发布具有改进内容的应用笔记。它也将附有源代码。
以上来自于百度翻译 以下为原文 We will be releasing the App Note with improved content soon. It will have the source code also attached with it. |
只有小组成员才能发言,加入小组>>
754个成员聚集在这个小组
加入小组2103 浏览 1 评论
1849 浏览 1 评论
3667 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1784 浏览 6 评论
1534 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
420浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
435浏览 2评论
381浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
913浏览 2评论
GMT+8, 2024-12-22 21:40 , Processed in 1.478478 second(s), Total 106, Slave 89 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
