你好:
PSoC Creator 4.2突然不能编程我的PSoC 6 BLE先锋套件或PSoC 4先锋套件。 工作良好后,现在找不到目标。构建工作正常,但没有编程活动。 我今天已经卸载并重新安装了PSoC Creator 4.2,但结果不变。 Windows报告CyPress KiPrg和CyPress KiPrdk 2,但是说“驱动程序不可用”。 同时,PSoC Creator的输出说: “ 此会话的日志文件位于:C:Value\\AdDATABStudioToPPSOC Calto-0.0.log 警告:找不到HID设备的文件描述符 ---------Bug启动:03/12/2018 17:01:13项目:第6课CAPSENSE,配置:ARM GCC 5.4-2016Q2-UPDATE调试---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 代码生成步骤是最新的。 ------------------------------------------------------------------------------------------------------------------------------------------------------------------ “ 当我选择调试目标时,得到下面的对话框: 关于解决这个港口和司机的问题有什么建议吗? 以上来自于百度翻译 以下为原文 Hello: PSoC Creator 4.2 is suddenly unable to program either my PSoC 6 BLE Pioneer Kit or the PSoC 4 Pioneer kit. After working well it now finds no targets. The build works OK but there is no programming activity. I have uninstalled and reinstalled PSoC Creator 4.2 today but the results are unchanged. Windows reports the Cypress KitPROG and Cypress KitProgK 2 but says "driver unavailable" Meanwhile the Output of PSoC Creator says: " Log file for this session is located at: C:UsersChrisAppDataLocalTempPSoC Creator-000.log Warning: Can't find HID-device's file descriptor --------------- Build Started: 03/12/2018 17:01:13 Project: Lesson 6 CAPSENSE, Configuration: ARM GCC 5.4-2016-q2-update Debug --------------- The code generation step is up to date. --------------- Build Skipped: 03/12/2018 17:01:17 --------------- " I get the following dialog when I go to select a debug target: Any advice on chasing down this port and driver issue? |
3个回答
你好CNTY31 30841,
你能帮我更多的信息吗? 1。你正在运行什么操作系统? 2。你能在PSoC程序员中看到Kitprogs吗?如果是,你能通过程序员编程设备吗?如果没有,程序员会显示什么信息? 三。当你说他们出现在设备管理器的KiPrg和KiTrp2时,它们出现在什么类别下?COM、USB控制器等。 4。你能告诉我们LED的状态吗?对于PSoC 4工具包-状态LED和PSoC 6工具包-ELD1到CED3附近PSoC 5LP? 5。当您卸载PSoC Creator时,您还可以删除“C:程序文件(x86) CyPress”中的PSoC Creator文件夹,并删除注册表项(open GeEdEd.EXE)并删除“HKEYAL LoalAxMauleWOW632节点 CyPress PSOC创建者”密钥项,然后安装PSoC Creator并查看是否修正了这个问题? 当做, Meenakshi Sundaram R 以上来自于百度翻译 以下为原文 Hello cnt_3130841, Can you help me some more info? 1. What OS are you running? 2. Are you able to see Kitprogs in PSoC Programmer? If yes, can you program the devices through programmer? If no, what message does Programmer show? 3. When you say they show-up as Kitprog and Kitprog2 in device manager, under what category do they appear? COM, USB controllers etc. 4. Can you tell us the LED status? For PSoC 4 kit - Status LED and for PSoC 6 kit - LED1 to LED3 near PSoC 5LP? 5. When you uninstall PSoC Creator, can you also delete the PSoC Creator folder in "C:Program Files (x86)Cypress" and delete the registry entries (Open regedit.exe and delete the "HKEY_LOCAL_MACHINESOFTWAREWOW6432NodeCypressPSoC Creator" key entry) and then install PSoC Creator and see if that fixes the issue? Regards, Meenakshi Sundaram R |
你好,MSUR 谢谢你的帮助,我很抱歉耽搁了这件事。我们有进步! 调用PSoC程序员似乎已经改变了这种情况。我现在可以看到程序员和Creator和Windows的目标不再抱怨丢失的驱动程序。这两个程序现在都在警告KitProg和KITPRO2版本号,并建议我使用程序员实用程序来更新固件。(见下面的截图)。 我尝试更新KiTrg固件,并成功地使用PSoC 4并通过PSoC Creator 4.2重新编程。 我尝试更新KITPRO2固件,并成功地使用PSoC 6并通过PSoC Creator 4.2重新编程。 我想我们已经解决了这个问题。你有什么建议,为什么事情的工作,然后停止? 谢谢,克里斯 以上来自于百度翻译 以下为原文 Hello msur - Thank you for your help; my apologies for delay in getting on with this. We have progress! Invoking PSoC Programmer seems to have changed the situation. I can now see the targets from both Programmer and Creator and Windows no longer complains of the missing driver. Both programs are now warning about the KitProg and KitProg2 version numbers and suggesting I use the Programmer Utility to update the firmware. (see screen shots below). I tried updating the KitProg firmware and had good success with PSoC 4 and reprogramming through PSoC Creator 4.2 I tried updating the KitProg2 firmware and had good success with PSoC 6 and reprogramming through PSoC Creator 4.2 I think we have solved the problem. Do you have any suggestions as to why things were working and then stopped? Thanks, Chris |
ly_0913 发表于 2018-10-24 11:24 我没有见过这么奇怪的问题。可能是因为打开的程序员可能已经复制/修复了所需的驱动程序(可能已经被删除/损坏)。 无论如何,好的问题是固定的,你都为PSoC 6再次设置 当做, Meenakshi Sundaram R 以上来自于百度翻译 以下为原文 I have not seen such a weird issue. Might be because opening Programmer might have copied/repaired the required drivers (which might have been deleted/corrupted). Anyway, good that the issue is fixed and you are all set for PSoC 6, again Regards, Meenakshi Sundaram R |
只有小组成员才能发言,加入小组>>
724个成员聚集在这个小组
加入小组1931 浏览 1 评论
1681 浏览 1 评论
3440 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1601 浏览 6 评论
1400 浏览 1 评论
GMT+8, 2024-6-21 13:27 , Processed in 0.756510 second(s), Total 82, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
