电子发烧友论坛扫一扫,分享给好友
我已经阅读了关于USB引导程序的文件AN73503。并且还下载该项目,但在组件更新之后,项目有伺服错误。
组件的VSON不兼容吗?我该怎么办?我的软件是PSoC创建者2.2,需要我把软件更新到PSoC创作者3.3。 QQ??20131?107131024.jPG 47.7 K 以上来自于百度翻译 以下为原文 I had read the document AN73503 which is about USB Bootloader. And also download the project, but after the component update, the project has servals errors. Is the verson of component don’t compatible each other? What should I do? My Software is PSoc Creater 2.2, Need I update the software to PSoc Creater 3.3.
5个回答
嗨,Sungd,也许你正在使用KiPro,PSoC5版本,你能找到PSoC3版本吗?我会搜索并稍后给你看。
以上来自于百度翻译 以下为原文 Hi sungd Maybe you are using KitProg, PSoC5 version Can you find PSoC3 version? I would be search it and show you later. |
AN73503,PSoC3设计包含2个项目Bootloader和BootloadReales,当然,必须使用相同的设备。你必须保证。
以上来自于百度翻译 以下为原文 AN73503, PSoC3 design is contain 2 projects Bootloader and Bootloadable Of course, those must use same device. You have to ensure that. |
我编译(更新项目后)与创建者3没有任何错误。
鲍勃 以上来自于百度翻译 以下为原文 I compiled (after updating the project) with Creator 3.0 without any errors. Bob |
谢谢大家的帮助。我没有迷你Prim3。我的主板是CY8CITK-030 PSoC 3开发套件,希望有人能提供MINI PROP3。我可以把我的软件更新到创建者3,让我试试
以上来自于百度翻译 以下为原文 Thank guys help. I haven't a Mini Prog3. My board is CY8CKIT-030 PSoc 3 Development kit. Hope someone can give the mini prog3. And I can update my software to Creator 3.0, Let me try it |
你不需要一个小程序3来编程-030KIT。
板上有两个(2个)USB连接器,一个是编程和调试,另一个是直接连接到PSoC3。我建议你看一下图表。 使用Bootloader时,必须使用第二个USB端口来更新新的可引导加载的芯片。 听起来有点复杂。 还有一些东西我记得(希望其他一些助手会跳进这里)我想用第二个USB作为引导装载器的项目应该运行在3.3V,但是我可能完全错了。 鲍勃 以上来自于百度翻译 以下为原文 You do not need a miniprog 3 to program a -030Kit. There are two (2) USB connectors on the board, one is for programming and debugging, the other is connected directly to the PSoC3. I suggest you to have a look into the schematics. When using a bootloader you will have to use the second USB-port to update the chip with the new bootloadable. Sounds a bit complicated There is something else I remember (Hopefully some other helper will jump in here) I have in mind that projects using the second USB as bootloader should run at 3.3V but I may be totally wrong with that. Bob |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 06:59 , Processed in 0.889402 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1353
