电子发烧友论坛|
嗨,
我是L6472的新手,通过阅读其数据表,我认为这将非常适合我的应用,它需要驱动NEMA34电机以相对较高的速度(例如每秒12转)。 我一直在阅读与L6472有关的AN4158并感到困惑 那里的一些概念,有人可以帮忙解释一下吗? 谢谢! 山姆 *)目标切换时间的概念(它设置控制系统的目标PWM频率)对我来说不清楚,这个参数和步进速度(或步进周期)之间的关系是什么? (或者这两个参数之间是否有任何关系?) 为什么拥有固定的PWM频率更好?这个PWM频率是否与在微步模式下产生微步相电流的PWM相同? *)它似乎使自动调整衰减和预测电流控制工作,需要正确设置6个参数:TOFF_MIN,TON_MIN,TOFF,TOFF_FAST,FAST_STEP,TSW。我不清楚这六个变量应该如何正确设置,是否有人应该为这些变量/参数设置值(或值范围)的分析步骤的概念示例? #l6472 以上来自于谷歌翻译 以下为原文 Hi, I'm new to L6472 here, and from reading its datasheet, I think it would be a perfect fit to my application which will need to drive a NEMA34 motor to go relative high speed (such as 12 rotations per sec.). I've been reading AN4158 which is related to L6472 and am puzzled by some of the concepts there, could someone help explain? thanks! Sam *) The concept of target switching time (it sets the target PWM frequency of the control system) is not clear to me,?what's the relationship between this parameter and the step speed (or step period)? (or is there any relationship between these two parameters?) And why it's better to have a fixed PWM frequency? is this PWM frequency the same PWM that creates the microstepped phase currents in microstep mode? *) it seems to make auto adjusted decay and predictive current control work, 6 parameters need to be set properly: TOFF_MIN, TON_MIN, TOFF, TOFF_FAST, FAST_STEP, TSW. It was not clear to me how these six variables shall be set properly, is there any concete example of the analytical steps someone should take to set values (or a value range) for these variables/parameters? #l6472 |
5个回答
pwm开关频率与输入步进脉冲频率无关。 PWM控制绕组中的电流。无论电机是旋转还是停止,它都会在大约20Khz时发出嗡嗡声。
有时更好的是具有固定的PWM频率以防止电机振铃噪声,而不是固定的关闭时间,使得频率根据电流而变化。 步进脉冲沿指针移动到一个表格,该表格指定正弦/余弦电流表和PWM应该工作的相位。 拉里 以上来自于谷歌翻译 以下为原文 The pwm switching frequency is not related to the input step pulse frequence. The PWM is controlling current in the winding. Its humming along at about 20Khz regardless if the motor is spinning or stopped. Its sometimes better to have a fixed PWM frequency to prevent motor ringing noise as opposed to a fixed off time that make the frequeny change depending on the current. The Step pulse moves along a pointer to a table that specifies where on the sine/cos current table and phase the PWM should work from. Larry |
我恢复这个旧线程,因为我有一些关于AN4158内容和L6472数据表内容的问题。
我正在研究L6472电流控制是如何工作的,我有点困惑。 参考L6472的数据表...... 在第40页,我读到T_FAST的默认值为''19h,1us / 5us'',但第45页的表格显示了不同的内容。从数字上讲,19h是默认值,但是正确的编码是:1us / 5us还是第45页的表格? ... T_FAST的表格是否正确? 参考AN4158 ...... 你在第21页写了Toff,但在L6472配置中哪个是与Toff相对应的寄存器?如何指定Toff持续时间? 我可以匹配所有其他参数,我可以找到在''预测电流控制'中使用的Toff_min但是我无法识别''自动调整衰减'中使用的Toff寄存器。 谢谢 以上来自于谷歌翻译 以下为原文 I resume this old thread, because I have some issue about AN4158 content and L6472 datasheet content. I'm studing how L6472 current control works, and I'm a little confused. With reference to L6472's datasheet... At page 40 I read that T_FAST has default value ''19h, 1us/5us'' but the table at page 45 says something different. Numerically speaking 19h is the default value, but which is the correct encoding: 1us/5us or the table at page 45? ... Is the table for T_FAST correct? With reference to AN4158... You write about Toff at page 21, but which is the register corresponding to Toff in L6472 configuration? How can I assign Toff duration? I can match all others parameters, I can find Toff_min used in ''predictive current control'' but I can't identify a Toff register used in ''auto adjusted decay''. Thanks |
嗨,
第40页表格中报告的值是错误的。实际值为TOFF_FAST = 4 us,FAST_STEP = 20 us。感谢您的反馈意见!我们将在下一个数据表版本中修复此问题。 当启用预测电流控制时,自动调节toff以便获得等于TSW的开关周期。 当禁用预测电流控制时,toff是恒定的并且等于TSW。 问候 恩里科 以上来自于谷歌翻译 以下为原文 Hi, The values reported in the table of page 40 are wrong. The actiual values are TOFF_FAST = 4 us, FAST_STEP = 20 us. Thanks for your feedback! We will fix this in the next datasheet release. When the predictive current control is enabled the toff is automatically adjusted in order to obtain a switching period equal to TSW. When the predictive current control is disabled the toff is constant and equal to TSW. Regards Enrico |
嗨,
我和Sam的原始问题中描述的是同一条船。我有L6472H发现板,想要驱动高达2400步/秒的步进器。在.8Amps /相和42伏。 有人能提供(或指向我)Sam问题第二部分的大纲/答案吗?具体来说,如何正确设置 :TOFF_MIN,TON_MIN,TOFF,TOFF_FAST,FAST_STEP,TSW 在阅读AN4158之后运行L6472,如果有的话 任何人应该采取的示例或分析步骤来设置这些变量/参数的值(或值范围)? 谢谢, 约翰 以上来自于谷歌翻译 以下为原文 Hi, I am in the same boat as outlined in Sam's original question. I have the L6472H Discovery board and want to drive a stepper as high as 2400step/sec. at .8Amps/phase and 42volts. Can someone provide (or point me to) an outline/answer to the 2nd part of Sam's questions? Specifically, how does one properly set : TOFF_MIN, TON_MIN, TOFF, TOFF_FAST, FAST_STEP, TSW to run the L6472 after reading AN4158, and if there is any example or analytical steps someone should take to set values (or a value range) for these variables/parameters? Thanks, John |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 01:19 , Processed in 0.809718 second(s), Total 50, Slave 44 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1496
