扫一扫,分享给好友
大家好,
我遇到了tri_mode_eth_mac许可证的一个奇怪问题。 2017年5月,我购买了tri_mode_eth_mac浮动站点许可证,如下所示: #这是在2017年5月29日星期一09:06:42生成的永久许可证2017INCREMENT tri_mode_eth_mac xilinxd 2018.05 permanent 9999 C3CB16424030 VENDOR_STRING = License_Type:Bought; myname,tri_mode_eth_mac,ip,permanent,_211358080_1777525743_210658574_706 ISSUER =“Xilinx Inc”NOtiCE = “此核心的许可证是在2017年5月30日为myname生成的。当使用此核心时,此核心的被许可方有责任遵守适用许可协议的所有条款和条件。” START = 2017年5月29日TS_OK# 在vivado licens manager中,它看起来像这样: 它在vivado 2016.4中运行良好,其中tri_mode_eth_mac_core具有版本9,Rev 6: 但是在vivado 2017.3中,tri_mode_eth_mac核心具有版本9,Rev 9,它显示为设计链接许可证。 而我无法生成比特流: 我的tri_mode_eth_mac许可证的版本限制为2018.5,它不能仅支持版本9 Rev 6而不支持版本9 Rev 9。 有人可以帮帮我吗? 以上来自于谷歌翻译 以下为原文 Hey guys, I'm encountering a strange problem with tri_mode_eth_mac license. In May 2017 I have bought a tri_mode_eth_mac floating site license which looks like this: # This is a permanent license generated on Mon May 29 09:06:42 UTC 2017 INCREMENT tri_mode_eth_mac xilinxd 2018.05 permanent 9999 C3CB16424030 VENDOR_STRING=License_Type:Bought;myname,tri_mode_eth_mac,ip,permanent,_211358080_1777525743_210658574_706 ISSUER="Xilinx Inc" NOTICE="The license for this core was generated for myname on 05/30/2017It is the responsibility of the Licensee of this core to adhere to all terms and conditions of the applicable license agreement when using this core." START=29-May-2017 TS_OK # and in vivado licens manager it looks like this: And it works fine in vivado 2016.4, in which the tri_mode_eth_mac_core has version 9, Rev 6: But in vivado 2017.3, in which the tri_mode_eth_mac core has version 9, Rev 9, it shows as a design linking license. And I can not generate bitstream with that: My tri_mode_eth_mac license has a version limit 2018.5, no way it can just support version 9 Rev 6 but not version 9 Rev 9. Can someone help me out here? |
5个回答
你好@ arley1224,
由于这与Vivado 2017.3相关,而您正在使用浮动许可,因此问题是由于: 从本答复记录:https://www.xilinx.com/support/answers/69377.html,您可以看到Vivado 2017.3现在使用FlexLM 11.14.1.0,旧的浮动服务器机器无法提供许可证,除非许可证实用程序版本 匹配或更新。 因此,所有浮动许可证用户必须升级其许可证实用程序,才能在Vivado 2017.3中获取许可证。 在你的情况下这是一个案例吗? 您的浮动许可证是否已使用flexlm实用程序(即lmgrd和xilinxd)v11.14启动并运行? 如果没有,那么这就是为什么Vivado无法从服务器检出许可证的原因。 请注意,Vivado 2017.3之前的所有Vivado版本都可以使用当前版本的flexlm工具正常工作,例如: v11.13。 但是,除非将实用程序升级到v11.14,否则Vivado 2017.3(以及较新的Vivado版本)将无法签出此许可证。 你可以打开一个命令提示符和CD到例如:../ xilinx / Vivado_2017.3 / Vivado/2017.3 / bin / unwrapped / lnx64.o(或者,如果是Windows OS,.. xilinx Vivado_2017。 3 Vivado 2017.3 BIN 展开 win64.o) 然后,从这里,请运行此命令:lmutil lmstat-a -c @(eglmutil lmstat -a-c 2100 @ ANATOLI_PC) 然后请查看lmgrd是否已启动且xilinxd是否也已启用,然后查看服务器启动的flexlm实用程序的版本? 你看到lmgrd和xilinxd的v11.14吗? 如果没有,请从下载页面(https://www.xilinx.com/support/download.html)获取这些实用程序,并将.zip文件提供给您的浮动许可证管理员(请注意,有专门针对Windows操作系统的实用程序) 并且还单独 - 对于Linux)。 然后要求管理员在服务器上的任何位置解压缩它。 然后他需要使用来自此位置的lmgrd来启动浮动许可证服务器,在那里他只需解压缩这些。 然后它将调用xilinxd供应商守护程序(也可以在与lmgrd v11.14相同的位置找到)。 就是这样,Vivado 2017.3将能够成功检测并检查必要的IP许可证,然后您的问题将得到解决。 希望这可以帮助。 亲切的问候, 阿纳托利 亲切的问候,Anatoli Curran,Xilinx技术支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hello @arley1224, As this is in relation to Vivado 2017.3 and as you are using floating licensing, the issue is due to this: From this Answer Record: https://www.xilinx.com/support/answers/69377.html, you can read that Vivado 2017.3 now uses FlexLM 11.14.1.0, which older floating server machines cannot provide licenses to unless the license utilities version matches or is newer. Therefore, all of the floating license users must upgrade their license utilities in order for licenses to be picked up in Vivado 2017.3. Is this a case in your situation? Is your floating license UP and running using flexlm utilities (i.e. lmgrd and xilinxd) v11.14? If not, then that is the reason why Vivado can't check out the licenses from the server. Please note that any Vivado releases prior Vivado 2017.3, will work fine using your current version of flexlm utilites e.g. v11.13. However, Vivado 2017.3 (and newer Vivado releases) won't be able to check out this license unless you upgrade your utilities to v11.14. Can you please open a command prompt and CD to the location such as e.g.: ../xilinx/Vivado_2017.3/Vivado/2017.3/bin/unwrapped/lnx64.o (or, if Windows OS, ..xilinxVivado_2017.3Vivado2017.3binunwrappedwin64.o) Then, from here, please run this command: lmutil lmstat –a –c Then please see if lmgrd is UP and xilinxd is UP too and then, see what version of flexlm utilities the server is/was started with? Do you see v11.14 for both lmgrd and xilinxd? If not, then please obtain these utilities from the downloads page (https://www.xilinx.com/support/download.html) and provide the .zip file to your floating license admin (please note that there are utilities specifically for Windows OS and also separately – for Linux). Then ask the admin to unzip this anywhere on the server. Then he needs to start the floating license server using the lmgrd from this location where he has just unzip these. It will then in turn will call the xilinxd vendor daemon (also found from the same location as lmgrd v11.14). And that is it then, Vivado 2017.3 will then be able to successfully detect and check out the necessary IP license and your issue will be resolved then. Hope this helps. Kind Regards, Anatoli Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. -------------------------------------------------------------------------View solution in original post |
你好@ arley1224,
由于这与Vivado 2017.3相关,而您正在使用浮动许可,因此问题是由于: 从本答复记录:https://www.xilinx.com/support/answers/69377.html,您可以看到Vivado 2017.3现在使用FlexLM 11.14.1.0,旧的浮动服务器机器无法提供许可证,除非许可证实用程序版本 匹配或更新。 因此,所有浮动许可证用户必须升级其许可证实用程序,才能在Vivado 2017.3中获取许可证。 在你的情况下这是一个案例吗? 您的浮动许可证是否已使用flexlm实用程序(即lmgrd和xilinxd)v11.14启动并运行? 如果没有,那么这就是为什么Vivado无法从服务器检出许可证的原因。 请注意,Vivado 2017.3之前的所有Vivado版本都可以使用当前版本的flexlm工具正常工作,例如: v11.13。 但是,除非将实用程序升级到v11.14,否则Vivado 2017.3(以及较新的Vivado版本)将无法签出此许可证。 你可以打开一个命令提示符和CD到例如:../ xilinx / Vivado_2017.3 / Vivado/2017.3 / bin / unwrapped / lnx64.o(或者,如果是Windows OS,.. xilinx Vivado_2017。 3 Vivado 2017.3 BIN 展开 win64.o) 然后,从这里,请运行此命令:lmutil lmstat-a -c @(eglmutil lmstat -a-c 2100 @ ANATOLI_PC) 然后请查看lmgrd是否已启动且xilinxd是否也已启用,然后查看服务器启动的flexlm实用程序的版本? 你看到lmgrd和xilinxd的v11.14吗? 如果没有,请从下载页面(https://www.xilinx.com/support/download.html)获取这些实用程序,并将.zip文件提供给您的浮动许可证管理员(请注意,有专门针对Windows操作系统的实用程序) 并且还单独 - 对于Linux)。 然后要求管理员在服务器上的任何位置解压缩它。 然后他需要使用来自此位置的lmgrd来启动浮动许可证服务器,在那里他只需解压缩这些。 然后它将调用xilinxd供应商守护程序(也可以在与lmgrd v11.14相同的位置找到)。 就是这样,Vivado 2017.3将能够成功检测并检查必要的IP许可证,然后您的问题将得到解决。 希望这可以帮助。 亲切的问候, 阿纳托利 亲切的问候,Anatoli Curran,Xilinx技术支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello @arley1224, As this is in relation to Vivado 2017.3 and as you are using floating licensing, the issue is due to this: From this Answer Record: https://www.xilinx.com/support/answers/69377.html, you can read that Vivado 2017.3 now uses FlexLM 11.14.1.0, which older floating server machines cannot provide licenses to unless the license utilities version matches or is newer. Therefore, all of the floating license users must upgrade their license utilities in order for licenses to be picked up in Vivado 2017.3. Is this a case in your situation? Is your floating license UP and running using flexlm utilities (i.e. lmgrd and xilinxd) v11.14? If not, then that is the reason why Vivado can't check out the licenses from the server. Please note that any Vivado releases prior Vivado 2017.3, will work fine using your current version of flexlm utilites e.g. v11.13. However, Vivado 2017.3 (and newer Vivado releases) won't be able to check out this license unless you upgrade your utilities to v11.14. Can you please open a command prompt and CD to the location such as e.g.: ../xilinx/Vivado_2017.3/Vivado/2017.3/bin/unwrapped/lnx64.o (or, if Windows OS, ..xilinxVivado_2017.3Vivado2017.3binunwrappedwin64.o) Then, from here, please run this command: lmutil lmstat –a –c Then please see if lmgrd is UP and xilinxd is UP too and then, see what version of flexlm utilities the server is/was started with? Do you see v11.14 for both lmgrd and xilinxd? If not, then please obtain these utilities from the downloads page (https://www.xilinx.com/support/download.html) and provide the .zip file to your floating license admin (please note that there are utilities specifically for Windows OS and also separately – for Linux). Then ask the admin to unzip this anywhere on the server. Then he needs to start the floating license server using the lmgrd from this location where he has just unzip these. It will then in turn will call the xilinxd vendor daemon (also found from the same location as lmgrd v11.14). And that is it then, Vivado 2017.3 will then be able to successfully detect and check out the necessary IP license and your issue will be resolved then. Hope this helps. Kind Regards, Anatoli Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
嗨阿纳托利,
谢谢你的超级快速回复。 我已使用您提供的命令检查了flexlm,它提供了以下信息: [检测lmgrd进程...] 许可证服务器状态:2100 @ wupdev01 wupdev01上的许可证文件:c: XILIN X windows_flexlm_v11.6 bin nt64 Xilinx-merged4-modified.lic: wupdev01:许可证服务器UP(主)v11.6 供应商deamon状态(在wupdev01上): xilinxd:UP v11.6 这意味着flexlm对于vivado 2017.3及更高版本来说太旧了吧? 我想我需要更新flexlm :) 感谢您的帮助,我会在更新后给出反馈。 以上来自于谷歌翻译 以下为原文 Hi Anatoli, thanks for the super quick reply. I have checked flexlm with the command you provide and it gives the following information: [detecting lmgrd processes...] License server status: 2100@wupdev01 License file(s) on wupdev01: c:XILIN Xwindows_flexlm_v11.6binnt64Xilinx-merged4-modified.lic: wupdev01: license server UP (master) v11.6 Vendor deamon status (on wupdev01): xilinxd: UP v11.6 It means the flexlm is too old for vivado 2017.3 and later version right? I think I need to update the flexlm :) Thanks for the help and I will give a feedback after the update. |
嗨再次@ arley1224,
实际上,对于能够检测和检出浮动许可证的Vivado 2017.3(以及更新版本的Vivado),您需要从v11.6到v11.14更新Flexlm实用程序(lmgrd和xilinxd)。 这可以从http://www.xilinx.com/support/download.html - >许可证管理工具 - 2017.4实用程序下载 这将解决您的问题。 祝你今天愉快。 亲切的问候, 阿纳托利 亲切的问候,Anatoli Curran,Xilinx技术支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hi again @arley1224, Indeed, for Vivado 2017.3 (and newer versions of Vivado) to be able to detect and check out your floating licenses, you've need to update your Flexlm utilities (both lmgrd and xilinxd) from v11.6 to v11.14. This can be downloaded from https://www.xilinx.com/support/download.html ->License Management Tools - 2017.4 Utilities This will fix your issue. Have a nice day. Kind Regards, Anatoli Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
使用更新的许可证服务器,问题得以解决。
谢谢! 以上来自于谷歌翻译 以下为原文 With the updated license server the problem is solved. Thanks! |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 18:54 , Processed in 0.664813 second(s), Total 50, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2154
