电子发烧友论坛|
我们刚刚购买了Vivado许可证并等待下载(Vivado和ISE 14.7),但只能下载Vivado。
我们购买的订单号是EVOU-150923-4H9I-77262897,所以我将等待您的帮助,指导我下载ISE 14.7嵌入式许可证的网站,因为它已经被要求知道这是购买Vivado的一部分 许可证包含ISE许可证。 问候! 以上来自于谷歌翻译 以下为原文 We just bought a Vivado License and waited to get access to download both (Vivado and ISE 14.7) but only Vivado was enabled to be downloaded. The order number of our purchase is EVOU-150923-4H9I-77262897, So I'll be waiting for your help to direct me the site to download the ISE 14.7 Embedded license, since it's suppoused to know that as a part of a purchase of Vivado license that it includes a ISE license. Regards! |
9个回答
你好@ luisr2d2
您不是启动此主题的人,因此您无法解决此问题。 @ciateqacstarted这个帖子,只有@ ciateqaccan关闭线程。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi @luisr2d2 You are not the one who started this thread so you can't close this issue. @ciateqac started this thread, Only @ciateqac can close the thread. View solution in original post |
你好@ ciateqac
是的,如快照/论坛帖子中所述,您应该在购买Vivado许可证时获得ISE许可证。 您能否共享Xilinx许可站点“创建新许可证”选项卡的快照(http://www.xilinx.com/getlicense) 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hello @ciateqac Yes, as mentioned in the snapshot/forums post, you should receive an ISE license with the purchase of Vivado license. Can you share a snapshot of "Create New License" tab of Xilinx Licensing Site (http://www.xilinx.com/getlicense) Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
你好Vinay!
这些是产品许可证实际状态的屏幕截图, 谢谢! 以上来自于谷歌翻译 以下为原文 Hi Vinay! These are the screenshots of the actual state of the product License, thanks! |
喜@ luisr2d2
看起来ISE许可证尚未添加到帐户中 请尝试通过以下链接登录,向客户支持团队提出服务请求。 http://www.xilinx.com/support/service-portal.html 他们会将其添加到您的帐户中。 以上来自于谷歌翻译 以下为原文 hi @luisr2d2 It looks like the ISE license has not been added to the account Please try opening a service request with customer support team by logging in from below link. http://www.xilinx.com/support/service-portal.html They will add it to your account. |
我的工作伙伴在她提到的链接中发布了她已经收到回复,问题已经解决了!
谢谢! 以上来自于谷歌翻译 以下为原文 My work partner posted by her way in the link you mentioned and she already received response, the problem has been solutioned! Thanks! |
喜@ luisr2d2
很高兴这个问题得到了解决。请通过将帖子标记为已接受的解决方案来关闭此线程 以上来自于谷歌翻译 以下为原文 hi @luisr2d2 Glad thatissue is solved.Please close this thread by marking the post as the accepted solution |
你好@ luisr2d2
您不是启动此主题的人,因此您无法解决此问题。 @ciateqacstarted这个帖子,只有@ ciateqaccan关闭线程。 以上来自于谷歌翻译 以下为原文 Hi @luisr2d2 You are not the one who started this thread so you can't close this issue. @ciateqac started this thread, Only @ciateqac can close the thread. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 01:23 , Processed in 0.860937 second(s), Total 90, Slave 73 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2464
