电子发烧友论坛|
我们在尝试在Ultrascale设计中使用TEMAC核心时遇到了问题。
我们购买并安装了核心的PROJ许可证,该许可证显示在我们的许可证管理器证书许可证中(参见附件),但是当我们尝试构建一个位文件时,我们收到以下消息...... 错误:[通用17-69]命令失败:此设计包含一个或多个不允许生成比特流的单元:ethernet_mac / trimac_fifo_block / trimac_sup_block / tri_mode_ethernet_mac_i / U0 / tri_mode_ethernet_mac_core(tri_mode_ethernet_mac_tri_mode_ethernet_mac_v9_0_4) 关于我们做错了什么的任何想法? Doc1.docx 152 KB 以上来自于谷歌翻译 以下为原文 We are encountering a problem in trying to use the TEMAC core in an Ultrascale design. We have purchased and installed a PROJ license for the core which shows up in our license manager certificate based licenses (see attachment), but when we attempt to build a bit file we get the following message... ERROR: [Common 17-69] Command failed: This design contains one or more cells for which bitstream generation is not permitted: ethernet_mac/trimac_fifo_block/trimac_sup_block/tri_mode_ethernet_mac_i/U0/tri_mode_ethernet_mac_core (tri_mode_ethernet_mac_tri_mode_ethernet_mac_v9_0_4) Any ideas on what we are doing wrong? Doc1.docx 152 KB |
7个回答
如果您使用eval许可证启动项目,然后迁移到购买的许可证,您可能会看到这样的错误。
就是这种情况,然后尝试重新生成IP,然后尝试创建一个比特流。 以上来自于谷歌翻译 以下为原文 If you started the project with an eval license then migrated to a purchased license you may see an error like this. It that was the case then try regenerating the IP and then try creating a bit stream. |
即使我支付了TEMAC的PROJ版本,核心的IP STATUS也将其显示为设计链接许可证,我理解它仅用于模拟。
如何让它能够生成位文件? 以上来自于谷歌翻译 以下为原文 Even though I paid for a PROJ version of the TEMAC, the IP STATUS for the core shows it as a Design Linking License, which I understand it to be for simulation only. How do I get it to be able to generate a bit file? |
您是否在许可页面上生成了新的许可证文件?
http://www.xilinx.com/ipcenter/ip_license/xilinx_license_key_types.htm 我已经有一段时间了,但我相信这是你必须要做的过程。 以上来自于谷歌翻译 以下为原文 Did you generate a new license file on the licensing page? http://www.xilinx.com/ipcenter/ip_license/xilinx_license_key_types.htm It's been a while since I've done this, but I believe that's the process that you have to do. |
@ david.mcdaniel
从共享的VLM快照中,我看到该工具正在启动设计链接许可证,这将只允许您进行实施前和模拟后的实施。 但是,您无法使用此许可证生成比特流。 您能否分享通过电子邮件发送给您的已购买的TEMAC Core许可证文件(.lic)? 还要共享xinfo报告。要生成此报告,请在Vivado TCL控制台中运行以下命令并共享生成的xinfo.txt文件。 report_environment -file /xinfo.txt --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @david.mcdaniel From the shared VLM snapshot, I see that the tool is picking up the design linking License which will only allow you perform both pre- and post-implementation simulation. However, you cannot generate bitstreams with this License. Can you please share the bought TEMAC Core license file (.lic) which was emailed to you? Also share the xinfo report. To generate this report, run the below command in Vivado TCL console and share the generated xinfo.txt file. report_environment -file --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
@ david.mcdaniel,
我怀疑问题是由于在生成核心许可证时选择了错误的hostID。 如果“hostID匹配”列设置为“否”,您可以签入VLM吗? 如果是,那么您将需要使用以下AR重新生成许可证: http://www.xilinx.com/support/answers/36136.html 将“主机ID匹配”列设置为“是”后,请按照以下步骤操作: 重新生成核心以克服此错误。 即, 1.打开项目并右键单击IP并选择“重置输出产品” 2.接下来,选择相同的IP并右键单击并选择“生成输出产品” 3.生成比特流 查看此答复记录以获取更多信息:http://www.xilinx.com/support/answers/58758.html --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @david.mcdaniel, I suspect the issue is due to incorrect hostID selected when generating the Core License. Can you check in VLM if the "hostID Match" column is set to "No". If yes, then you will need to regenerate the License using the following AR: http://www.xilinx.com/support/answers/36136.html Once the HOST ID Match column is set to Yes then follow the below steps: Regenerate the core to overcome this error. i.e., 1. Open the project and right-click on the IP and select "reset output products" 2. Next, select the same IP and right click and select "Generate output products" 3. Generate bitstream Check this answer record for more information: http://www.xilinx.com/support/answers/58758.html --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
@ david.mcdaniel,
这篇文章的任何更新? 如果提供的建议没有用,请分享.lic和xinfo.txt文件。 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @david.mcdaniel, Any update on this post? Please share the .lic and xinfo.txt file if the suggestion provided was not helpful. --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
如果在Linux操作系统上发生这种情况,请设置(setenv)您的XILINXD_LICENSE_FILE环境变量以指向许可证文件的位置,例如:/ home//.Xilinx/Xilinx_10G.lic
例如。: setenv XILINXD_LICENSE_FILE /home//.Xilinx/Xilinx_10G.lic 我们之前已经看到过这个解决了其他一些用户的问题。 即使许可证在您的主目录中,Vivado许可证管理器(VLM)也可以看到许可证,但由于某种原因,Vivado无法在此主目录中检测到此许可证,因此如果您将XILINXD_LICENSE_FILE设置为指向此位置,则Vivado应该 知道在哪里查看所需的许可证文件。 完成后,在Vivado中,检查状态(report_ip_status),看看现在是否检测到Bought而不是Design_Linking。 如果是这样,那么您需要重置并重新生成输出产品并重新运行所有内容,综合,实现等,然后查看错误是否会消失。 顺便说一句,在你的截图中我看不到Bought而是一个Design_Linking for ten_gig ... core。 您是否真的成功安装了此购买的许可证文件? 亲切的问候,Anatoli Curran,Xilinx技术支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 If this is happening on the Linux OS, please set (setenv) your XILINXD_LICENSE_FILE environment variable to point to the location of the license file, e.g.: /home/ e.g.: setenv XILINXD_LICENSE_FILE /home/ We’ve seen this solving the problem before for some other users. Even if license is within your home directory, Vivado License Manager (VLM) can see the license, however for some reason Vivado can’t detect this license within this home directory, so if you set XILINXD_LICENSE_FILE to point to this location, Vivado should then know where to look at for the required license file. Once done, in Vivado, check the status (report_ip_status) and see if this now detects Bought instead of Design_Linking. If so, you would then need to reset and regenerate output products and re-run everything, Synthesis, Implementation, etc and see if the error would get away then. BTW, in your screenshot I don’t see Bought but a Design_Linking for ten_gig… core. Have you actually managed to successfully install this purchased license file? Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 06:49 , Processed in 0.917598 second(s), Total 84, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2102
