电子发烧友论坛扫一扫,分享给好友
Vivado不断在vivado项目目录中创建new.jou和.log备份文件。
如何禁用这些文件的创建和/或备份? 以上来自于谷歌翻译 以下为原文 Vivado is constantly creating new .jou and .log backup files in the vivado project directory. How do I disable the creation and/or backup of these files? |
6个回答
然后在%APPDATA%/ Roaming / Xilinx / Vivado /(或者用于Linux的$ HOME / .Xilinx / Vivado / init.tcl)中创建一个init.tcl文件并添加此行(这将禁用备份文件)
set_param general.maxBackupLogs 0 FlorentProduct应用工程师 - Xilinx技术支持EMEA ------------------------------------------ -------------------------------------------------- ----------------------------不要忘记回复,kudo,并接受作为解决方案。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Then create an init.tcl file in %APPDATA%/Roaming/Xilinx/Vivado/ (or $HOME/.Xilinx/Vivado/init.tcl for linux) and add this line (this will disable the backup files) set_param general.maxBackupLogs 0 Florent Product Application Engineer - Xilinx Technical Support EMEA ------------------------------------------------------------------------------------------------------------------------ Don't forget to reply, kudo, and accept as solution. View solution in original post |
嗨,如果你从命令行发送vivado,你可以使用:vivado -nolog -nojournalRegards,Florent
FlorentProduct应用工程师 - Xilinx技术支持EMEA ------------------------------------------ -------------------------------------------------- ----------------------------不要忘记回复,kudo,并接受作为解决方案。 以上来自于谷歌翻译 以下为原文 Hi, If you are lauching vivado from the command line, you can use: vivado -nolog -nojournal Regards, FlorentFlorent Product Application Engineer - Xilinx Technical Support EMEA ------------------------------------------------------------------------------------------------------------------------ Don't forget to reply, kudo, and accept as solution. |
嗨,这也是答案:https://forums.xilinx.com/t5/Vivado-TCL-Community/How-to-disable-backup-log-and-jou-files/td-p/288491并禁用
只有备份文件 FlorentProduct应用工程师 - Xilinx技术支持EMEA ------------------------------------------ -------------------------------------------------- ----------------------------不要忘记回复,kudo,并接受作为解决方案。 以上来自于谷歌翻译 以下为原文 Hi, Here is also the answer: https://forums.xilinx.com/t5/Vivado-TCL-Community/How-to-disable-backup-log-and-jou-files/td-p/288491 And to disable also only the backup filesFlorent Product Application Engineer - Xilinx Technical Support EMEA ------------------------------------------------------------------------------------------------------------------------ Don't forget to reply, kudo, and accept as solution. |
我没有从命令行启动。
由于vivado错误,我必须双击.xpr文件启动。 以上来自于谷歌翻译 以下为原文 I'm not launching from the comand line. Due to a vivado bug I have to launch by double clicking the .xpr file. |
set_param general.maxBackupLogs 0 FlorentProduct应用工程师 - Xilinx技术支持EMEA ------------------------------------------ -------------------------------------------------- ----------------------------不要忘记回复,kudo,并接受作为解决方案。 以上来自于谷歌翻译 以下为原文 Then create an init.tcl file in %APPDATA%/Roaming/Xilinx/Vivado/ (or $HOME/.Xilinx/Vivado/init.tcl for linux) and add this line (this will disable the backup files) set_param general.maxBackupLogs 0 Florent Product Application Engineer - Xilinx Technical Support EMEA ------------------------------------------------------------------------------------------------------------------------ Don't forget to reply, kudo, and accept as solution. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 00:39 , Processed in 2.225554 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
12005
