电子发烧友论坛|
是否可以删除NVIDIA许可证管理器中的许可客户端?
某些非持久性VDI客户端已被删除但仍在NVIDIA许可证管理器中注册,因为租约时间尚未到期。 有没有办法缩短租约时间或从NVIDIA许可证管理器中删除客户端? 以上来自于谷歌翻译 以下为原文 Is it possible to remove a licensed client in the NVIDIA License manager? Some non-persistent VDI clients are already deleted but are still registered in the NVIDIA license manager because the lease time is not expired. Is there a way to shorten the lease time or delete the client from the NVIDIA license manager? |
9个回答
当然,只需减少许可证服务器Web UI中的租用时间。
默认值为7天,因此将其减少为1天。 问候 西蒙 以上来自于谷歌翻译 以下为原文 Sure, just reduce the lease time in License server Web UI. The default is 7 days so reduce it to 1 day as example. Regards Simon |
UI中的该选项在哪里以及您使用的是哪个版本的许可证管理器?
以上来自于谷歌翻译 以下为原文 Where is that option in the UI and what version of the license manager are you using? |
嗨,
抱歉,是我的错。 这是通过RegKey完成的: https://docs.nvidia.com/grid/latest/grid-licensing-user-guide/index.html#windows-registry-grid-license-settings 请参阅LicenseInterval ... 问候 西蒙 以上来自于谷歌翻译 以下为原文 Hi, sorry, my mistake. This is done with the RegKey: https://docs.nvidia.com/grid/latest/grid-licensing-user-guide/index.html#windows-registry-grid-license-settings See LicenseInterval... Regards Simon |
我相信旧许可证服务器上有一个“Drop Client”选项,但是我没有在最新的GRID5许可证服务器上看到此选项。
REGKEY似乎是客户端删除的唯一选择 以上来自于谷歌翻译 以下为原文 I believe there was a 'Drop Client' option on the older licence server however i don't see this option on the latest GRID5 license server. REGKEY looks to be the only option for client removal |
嗨Nealus,
你是对的。 不幸的是,此选项已从Flexera中删除。 我们正在努力解决这个问题,或者改进选择。 问候 西蒙 以上来自于谷歌翻译 以下为原文 Hi Nealus, you're right. Unfortunately this option was removed from Flexera. We're working on this to get the option back or another improvement. Regards Simon |
None
以上来自于谷歌翻译 以下为原文 We have Tesla M10s and are running the 5.0 management console and cannot remove licenses that were assigned to deleted VMs. We also do not have those registry entries mentioned since our licenses do not have an expiration date but are perpetual instead. What makes it worse is that Nvidia support never calls back after the case is opened. Is there a workaround to this issue for customers that have perpetual (permanent) licensing? |
嗨Streuber,
解决方法在上面发布了3个帖子。 请实施RegKey。 问候 西蒙 以上来自于谷歌翻译 以下为原文 Hi Streuber, the workaround was posted 3 posts above. Please implement the RegKey. Regards Simon |
我是否必须在Vm或许可证服务器上或两者上设置LicenseInterval REGKEYS?
以上来自于谷歌翻译 以下为原文 Do I have to set LicenseInterval REGKEYS on Vm or on License Server or both? |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3396 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3818 浏览 4 评论
/9
GMT+8, 2025-12-1 18:17 , Processed in 0.980314 second(s), Total 88, Slave 71 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
5717
