电子发烧友论坛|
我看到所有评估和免费许可证都是节点锁定许可证。
是否有任何FlexLM类型的许可证可用作临时使用许可证? 以上来自于谷歌翻译 以下为原文 I see that all of the evaluation and no-charge licenses are node-locked licenses. Are there any FlexLM type licenses available as temporary use licenses? |
4个回答
Hiscott.auld@motorolasolutions.com
您在寻找Vivado Design Suite的免费浮动许可吗? 30天评估许可仅用于评估目的。 Vivado WebPACK许可证是无节点许可证,您可以在其中生成一个许可证并在其他计算机上使用它。 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi scott.auld@motorolasolutions.com Are you looking for free floating licenses of Vivado Design Suite?? 30-day evaluation licenses are for evaluation purposes only. Vivado WebPACK license is node-free license where you can generate one license and use it on other machines. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
我们在气隙网络上的一个设计团队正试图在虚拟机上测试FlexLM服务器以获得许可和安装。
想获得一个临时许可证文件来测试你的工具。 以上来自于谷歌翻译 以下为原文 One of our design teams on an air-gapped network is trying to test a FlexLM server on a virtual machine for licensing & wanted to get a temporary license file to test your tools with. |
请联系您当地的Xilinx销售代表(Xilinx FAE),XFAE将能够为您提供45天的浮动评估Vivado许可。
他们可以将此类评估许可证添加到客户帐户。 问候, 阿纳托利 亲切的问候,Anatoli Curran,Xilinx技术支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Please contact your local Xilinx sales representative (Xilinx FAE) and XFAE will be able to provide you with a Floating 45-days Evaluation Vivado license. They have access to add this type of evaluation licenses to the customers accounts. Regards, Anatoli Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
scott.auld@motorolasolutions.com,
请参阅此链接以联系FAE:http://www.xilinx.com/about/contact/authorized-distributors.html 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 scott.auld@motorolasolutions.com, Refer this link for contacting FAE: http://www.xilinx.com/about/contact/authorized-distributors.html Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
只有小组成员才能发言,加入小组>>
3148 浏览 7 评论
3437 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2899 浏览 9 评论
4100 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3083 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1359浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1197浏览 1评论
/9
GMT+8, 2025-12-13 22:42 , Processed in 0.881159 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3222
