电子发烧友论坛|
嗨,
我有spartan 3a评估套件,我试图将Chipscope ILA添加到我的设计中但是我在实现的设计部分中收到了错误。 错误:NgdBuild:1317 - 使用核心芯片eye_ila_v1需要ChipScopePro许可证。 以下块是核心芯片的实例.cope_ila_v1:错误:安全性:14 - 没有可用于'ChipScopePro'的功能.ERROR:NgdBuild:1316 - 试图获得ChipScopePro许可证时遇到问题。 以上来自于谷歌翻译 以下为原文 HI , I have spartan 3a eval kit and I tried to add Chipscope ILA to my design but I received error in implemented design part. ERROR:NgdBuild:1317 - Using core chipscope_ila_v1 requires a ChipScopePro license. The following blocks are instances of core chipscope_ila_v1: ERROR:Security:14 - No feature was available for 'ChipScopePro'. ERROR:NgdBuild:1316 - A problem was encountered attempting to get the ChipScopePro license. |
7个回答
嗨,由于3个许可证中只有第1个许可证对ISE和webpack许可证有用。
ISE具有ILA / chipscope的功能,但您需要单独的许可才能使用此功能。您可以联系Xilinx销售/ Xilinx分销商进行销售相关查询。谢谢,Yash 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi, As out of 3 license only 1st license is useful for ISE and i.e. webpack license. ISE has feature of ILA/chipscope but you need separate license to use this feature. You can contact Xilinx sales/Xilinx distributor for sales related query. Thanks, YashView solution in original post |
嗨,请在此处附上您的许可文件。
谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, Please attach your license file here. Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
我的电子邮件中有这三个文件。
Xilinx.lic 1 KB Xilinx(1).lic 2 KB Xilinx(2).lic 2 KB 以上来自于谷歌翻译 以下为原文 I have these three files in my email. |
嗨,这些许可证文件都没有支持chipcope功能。
谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, None of these license files has chipscope feature support.Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
ISE具有ILA / chipscope的功能,但您需要单独的许可才能使用此功能。您可以联系Xilinx销售/ Xilinx分销商进行销售相关查询。谢谢,Yash 以上来自于谷歌翻译 以下为原文 Hi, As out of 3 license only 1st license is useful for ISE and i.e. webpack license. ISE has feature of ILA/chipscope but you need separate license to use this feature. You can contact Xilinx sales/Xilinx distributor for sales related query. Thanks, Yash |
嗨@fatimayazdandoust,
请通过标记解决方案来关闭线程。 谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi @fatimayazdandoust , Please close the thread by marking the solution. Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
只有小组成员才能发言,加入小组>>
3148 浏览 7 评论
3437 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2900 浏览 9 评论
4108 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3083 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1363浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1202浏览 1评论
/9
GMT+8, 2025-12-15 14:17 , Processed in 1.011035 second(s), Total 86, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2200
