电子发烧友论坛|
SDK说我的许可证不好。
我如何获得良好的许可证? 我去了配置选项,但仍然收到许可证错误。 以上来自于谷歌翻译 以下为原文 SDK says my license is no good. How do I get a good license? I went to the configuration option but am still getting license error. |
10个回答
我正在重新安装ISE_DS 13.4。
我可能安装了错误的版本,从而导致许可证问题。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 I am reinstalling ISE_DS 13.4. I may have installed the wrong version and thus the license issues. View solution in original post |
你好
您看到的错误是什么以及您使用的是哪种版本的工具? 您是否拥有购买的许可证或webpack许可证。 问候,萨蒂什----------------------------------------------- --- --------------------------------------------请注意 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用的帖子。感谢.-- ---------------------------- --------------------- ---------------------- 以上来自于谷歌翻译 以下为原文 Hi What is the error you are seeing and which version of tools are you using? Do you have a purchased license or webpack license. Regards, Satish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful. --------------------------------------------------------------------------------------------- |
你好,你面临的错误是什么?
您可以查看以下链接以获取更多信息-http://www.xilinx.com/products/design-tools/vivado.html您可以在Vivado Tcl控制台中运行以下命令并共享生成的输出文件.report_environment -file env。 文本 问候,阿希什----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hello, What is the error you are facing? You can check below link for further information - http://www.xilinx.com/products/design-tools/vivado.html Can you please run below command in Vivado Tcl console and share the generated output file. report_environment -file Regards, Ashish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
我有ISE 13.4版本。
这是我附加的错误。 以上来自于谷歌翻译 以下为原文 I have ISE 13.4 version. This is the error I get attached. |
您使用什么操作系统?
因为当您使用ubuntu / linux时,它可能无权将许可证加载到您的许可证文件夹中。 以上来自于谷歌翻译 以下为原文 What operating system are you using? Because when you use ubuntu/linux it might not have the rights to load you license into your license folder. |
嗨,转到开始 - & gt; xilinx设计工具 - & gt;
ise design suite - & gt; 饰品 - &安培; GT; xinfo系统检查程序。 这将生成xinfo.txt文件。请在此处附加您的许可证文件和xinfo.txt文件。打开xlcm并将XILINXD_LICENSE_FILE指向许可证文件的位置。 重新启动SDK并查看它是否有效。谢谢.Deepika。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi, Go to start-->xilinx design tools --> ise design suite --> accesories--> xinfo system checker. This generates xinfo.txt file. Please attach your license file and xinfo.txt file here. Open xlcm and point XILINXD_LICENSE_FILE to the location of the license file. Restart SDK and see if it works. Thanks. Deepika.Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
嗨,
该错误明确指出您没有使用XPS的许可。 请附上Xilinx许可证文件以及xinfo文件,以了解此处报告的错误是否无效。 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hi, The error clearly states that you do not have license to use XPS. Please attach the Xilinx license file along with the xinfo file to know if the error reported here is Invalid. --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
1个2的infor.txt文件副本
xinfo.txt 68 KB 以上来自于谷歌翻译 以下为原文 1 of 2 copy of infor.txt file |
Xilinx Lic的2份副本中的2份。
Xilinx.lic 1 KB 以上来自于谷歌翻译 以下为原文 2 of 2 copy of Xilinx Lic. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 17:47 , Processed in 0.850344 second(s), Total 60, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1176
