我下载了试用Vivado许可证以处理旧的ISE项目,我正在尝试在设计中使用芯片范围专业版。
当我去创建位文件时,我收到以下错误:错误:NgdBuild:1316 - 尝试获取ChipScopePro许可证时遇到问题。 我认为这是因为它不喜欢我出于某种原因使用的Vivado许可证。 我的印象是vivado试用许可证允许我在30天内访问所有这些工具。 我在整个许可证管理器上寻找可以启用芯片范围专业版的东西,但我发现除了vivado试用许可证之外什么都没有? 我需要使用chipcope pro吗? Xilinx.lic 1 KB 以上来自于谷歌翻译 以下为原文 I downloaded the trial Vivado license to work on an old ISE project, and I am trying to use chip scope pro in the design. When I go to create the bitfile I get the following error: ERROR:NgdBuild:1316 - A problem was encountered attempting to get the ChipScopePro license. I assume this is because it doesn't like the Vivado license that I have for some reason. I was under the impression that the vivado trial license would grant me access to all of these tools for the 30 days. I looked all over the license manager for something that would enable chip scope pro, but I found nothing but the vivado trial license? Is there a separate one that I need to use chipscope pro? Xilinx.lic 1 KB |
6个回答
你好@ bkanhofer
您附带的许可证是Vivado HLS许可证,可以单独与Vivado HLS工具一起使用。 这不适用于ISE / Chipscope。 谢谢, 迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi @bkanhofer The license which you attached is Vivado HLS license which can be used with Vivado HLS tool alone. This does not work with ISE/Chipscope. Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
这就是我所怀疑的。
有没有办法获得ISE /芯片范围专业版的试用许可证? 以上来自于谷歌翻译 以下为原文 That's what I suspected. Is there a way to get a trial license for ISE/chip scope pro? |
你好@ bkanhofer
ISE 30天评估许可证可帮助您使用chipcope。 你使用的是哪种设备? 你能用Vivado吗? 我们已经停止了ISE的评估流程,并且一般不提供ISE 30天评估许可。 请联系您的Xilinx FAE以提交请求。 谢谢, 迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi @bkanhofer ISE 30 days evaluation license helps you to use chipscope. Which device are you using? Can you use Vivado? We have stopped the evaluation process for ISE and ISE 30-day evaluation license is not provided generally. Please contact your Xilinx FAE to submit the request. Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
我们使用的是Spartan6,所以我很确定我们会遇到ISE。
我们很快就会转向新芯片,所以我们只需要ISE和chipcope暂时进行一些维护活动。 以上来自于谷歌翻译 以下为原文 We are using a Spartan6, so I'm pretty sure we are stuck with ISE. We are moving to a new chip soon, so we only need ISE and chipscope temporarily for some maintenance activities. |
我们目前还没有FAE,我们可以联系谁?
以上来自于谷歌翻译 以下为原文 Also we don't currently have an FAE, who can we contact? |
嗨,
您可以从下面的列表中联系您的FAE。 http://www.xilinx.com/about/contact/authorized-distributors.html 以上来自于谷歌翻译 以下为原文 Hi , You can contact your FAE from below list. http://www.xilinx.com/about/contact/authorized-distributors.html |
只有小组成员才能发言,加入小组>>
2267 浏览 7 评论
2671 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2159 浏览 9 评论
3233 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2302 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
551浏览 1评论
1620浏览 1评论
121浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2271浏览 0评论
589浏览 0评论
GMT+8, 2024-8-10 17:16 , Processed in 1.295486 second(s), Total 89, Slave 72 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
