电子发烧友论坛扫一扫,分享给好友
大家好!
我正在安装Vivado版本2014.2并在win 7 64位上安装浮动许可证 我做了: 以administrator1身份打开命令提示符。 导航到/win32.o(对于32位计算机)或/win64.o(对于64位计算机)2。 运行命令:installanchorservice.exe xilinxd.exe Vivado-Software(在计算机上创建可信存储)3。 运行命令:xlicsrvrmgr.exe -cr request.xml(创建request.html文件以生成许可证)在步骤3之后,您将获得request.xml和request.html。在您的Internet浏览器中使用该html并生成所需的许可证 。 (但是,当我在此步骤中生成许可证时,我不会看到xilinx网站向我询问有关ID主机的信息,因为它是UG973引导的!可能是自动的吗?) 生成许可证后,您将获得新的* .xml文件。 使用该xml并运行步骤#4.4。 运行以下命令:xlicsrvrmgr.exe -p Xilinx_Licenese.xml(处理收到的许可证文件并保存到可信存储)。 之后我通过命令检查:xlicsrvrmgr.exe -v我得到了结果: 这可以吗 ? 当我签入Vivado License Manager工具时:在View License status选项卡中: 我还没有在Activation Base Licenses路径中看到任何工具或IP! 所以我认为Lisence没有成功激活???? 我想知道我怎么知道我的执照是好的? 以上来自于谷歌翻译 以下为原文 hi all! I'm installing Vivado edition 2014.2 with floating license on win 7 64 bit I did : Open Command prompt as administrator 1. Navigate to the 2. Run the command: installanchorservice.exe xilinxd.exe Vivado-Software (Creates a trusted storage on the machine) 3. Run the command: xlicsrvrmgr.exe -cr request.xml (Creates a request.html file to generate the license) After step 3 you will get request.xml and request.html. Use that html in your internet browser and generate the required license. (but, when I generate License in this step, i dont see xilinx site ask me about ID host as UG973 guided ! May be it is automatic ?) After generating the license you will get new *.xml file. Use that xml and run step # 4. 4. Run the command: xlicsrvrmgr.exe -p Xilinx_Licenese.xml (Process the received license file and saved to trusted storage). After that I check by command : xlicsrvrmgr.exe -v and i got result : Is that ok ? when I check in Vivado License Manager tool: in View License status tab: I don't still see any tool or IP in Activation Base Licenses path !!!! so I think that Lisence is not actived successfully ???? and I want to know that how can i know my license is OK ? |
8个回答
你好,
通过创建的.html文件登录Xilinx许可站点后,无需指定主机ID信息。 它由Vivado License Manager自动从您的系统中获取。 为了提供基于激活的许可证,您需要一个基本的许可证文件,如我之前的响应中所述。 有关详细信息,请参阅以下UG页面#49 http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_2/ug973-vivado-release-notes-install-license.pdf 问候,阿希什----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hello, You need not to specify Host ID information once you login to the Xilinx Licensing Site through the created .html file. It is automatically taken from your system by the Vivado License Manager. In order to serve the activation based license, you need a basic license file as described in my earlier response. For the further details, you can refer to page #49 of below UG http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_2/ug973-vivado-release-notes-install-license.pdf Regards, Ashish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ----------------------------------------------------------------------------------------------View solution in original post |
你好,
从快照中,您似乎可以成功处理许可证。 现在在服务器上执行以下步骤。 使用以下三行创建示例.lic文件: 服务器 USE_SERVER 供应商xilinxd 2.运行命令:lmgrd -c sample.lic -l debug.log 然后在客户端机器上 1.打开VLM 2.选择“许可证搜索位置”并将XILINXD_LICENSE_FILE指向端口@ servername 现在检查Vivado License Manager工具:inView许可证状态选项卡:在客户端计算机上。 问候,阿希什----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hello, From the snapshot, it seems that you are able to process the license succesfully. Now do the following steps on server.
2. Run the command: lmgrd -cSERVER Then on client machine 1. Open VLM2. Select "License Search Location" and point XILINXD_LICENSE_FILE to port@servername Now check in Vivado License Manager tool: in View License status tab: on client machine.Regards, Ashish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
非常感谢你的回复!
但是,我不知道我的host_ID,因为当我在xilinx网站上生成.xml时,它没有像我上面所说的那样问我? 现在我只在我的服务器机器上运行Vivado 2014.2! 我怎样做 ? 以上来自于谷歌翻译 以下为原文 thanks for your reply so much! but, I dont know my host_ID because when i generate .xml on xilinx site, it did not ask me as I said above ? now i only run Vivado 2014.2 on my server machine! how i do ? |
当我在xilinx网站上完成生成.xml文件时,我得到:
我不知道为什么我的主机名和host_ID就是那个???? 以上来自于谷歌翻译 以下为原文 when I complete generate .xml file on xilinx site i get : i dont know why my Host name and host_ID is as that ???? |
你好,
通过创建的.html文件登录Xilinx许可站点后,无需指定主机ID信息。 它由Vivado License Manager自动从您的系统中获取。 为了提供基于激活的许可证,您需要一个基本的许可证文件,如我之前的响应中所述。 有关详细信息,请参阅以下UG页面#49 http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_2/ug973-vivado-release-notes-install-license.pdf 问候,阿希什----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hello, You need not to specify Host ID information once you login to the Xilinx Licensing Site through the created .html file. It is automatically taken from your system by the Vivado License Manager. In order to serve the activation based license, you need a basic license file as described in my earlier response. For the further details, you can refer to page #49 of below UG http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_2/ug973-vivado-release-notes-install-license.pdf Regards, Ashish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
嗨,
在基于激活的许可方案中,激活使用客户端或服务器硬盘驱动器上的受信任区域来存储授权凭证,而不是要求存在文件来授权计算机。 从Vivado 2014.1安装程序开始,将自动安装并初始化此可信存储区域。 当Vivado工具查找许可证功能时,如果此可信存储区域包含正确的授权,则允许它们运行。 所需的HOSTID信息将通过您创建的request.xml传播到您的许可证帐户。 以上来自于谷歌翻译 以下为原文 Hi, In Activation based licensing scheme,Instead of requiring a file to be present to authorize a machine, Activation uses a trusted area on the client or server’s hard-drive to store the authorization credentials. This trusted storage area will automatically be installed and initialized beginning with the Vivado 2014.1 installer. When the Vivado tools look for a license feature, they are allowed to run if this trusted storage area contains the proper authori zation. The requried HOSTID information will be propagated to your license account through the request.xml that you have created. |
嗨,要知道机器的hostid,请执行以下命令:lmutil lmhostidThanks,Vinay
-------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, To know the machine's hostid, run this command: lmutil lmhostid Thanks, Vinay-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 05:52 , Processed in 1.048243 second(s), Total 86, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3687
