我正在尝试在第二台Linux计算机(LInux Mint)上安装WebPack。
内置的许可证管理器在第一台计算机上无法为我工作,但通过访问Xilinx许可站点,我可以通过电子邮件向我发送许可证。 这适用于第一台计算机。 现在我无法为我的第二台计算机生成WebPack许可证,因为我已经在我的帐户上分配了一个。 虽然有人说有些人认为WebPack许可证不是节点锁定的,但由于主机ID不匹配,因此不能简单地复制和使用第二台机器上的第一个许可证。 我可以在两台机器上运行WebPack吗? 如果是这样,我怎样才能获得许可证,而不是在Xilinx上创建第二个帐户? 以上来自于谷歌翻译 以下为原文 I am trying to install the WebPack on a second Linux computer (LInux Mint). The built-in license manager did not work for me on the first computer, but by going to the Xilinx Licensing Site I was able to get a license emailed to me. This worked fine for the first computer. Now I am unable to generate a WebPack license for my second computer because I already have one assigned on my account. Although is said somewhare that the WebPack license was not node-locked, it does not work to simpy copy and use the first license on the second machine because Host ID does not match. Am I allowed to have the WebPack running on two machines? If so, how can I get a license, short of creating a second account with Xilinx? |
6个回答
嗨,您使用的是vivado webpack还是ise webpack?
你可以在这里附上许可吗?webpack许可证不是节点锁定的,因此它可以在不同于生成它的机器上使用。谢谢,Deepika。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi, Are you using vivado webpack or ise webpack? Can you attach the license here? The webpack licenses are not node locked hence it can be used on a different machine than the one for which it is generated for. Thanks, Deepika.Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
我已通过“产品许可”页面上的“管理许可证”选项卡附加了通过复制/粘贴创建的ISE WebPack许可证文件。
它似乎包含特定的节点ID信息。 谢谢你的帮助。 Xilinx.lic 1 KB 以上来自于谷歌翻译 以下为原文 I have attached the ISE WebPack license file that I created by copy/paste from the "Manage Licenses" tab on the "Product Licensing" page. It appears to have specific Node ID information contained in it. Thanks for your help. Xilinx.lic 1 KB |
嗨,
从许可证文件中,这看起来是节点锁定许可证。 您是否生成此许可证或从其他人那里收到? 你能尝试重新生成许可吗? 谢谢, 迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi, From the license file this looks to be node locked license. Did you generate this license or received from anyone else? Can you try regenerating the license? Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
是的,它是节点锁定的。
这就是给我这个问题的原因。 我通过转到许可页面来生成它,要求获得WebPack许可证并将其从Xilinx通过电子邮件发送给我。 当我尝试使用内置许可证管理器(XLCM)工具获取许可证时,它不起作用。 我曾多次尝试让XLCM给我许可,但什么都没发生。 现在我无法生成任何新许可证,因为许可证管理器网站说我已经拥有一个:所有选项都被禁用。 看起来我完全搞砸了。 除非你有更好的建议,否则我将使用我妻子的电子邮件地址并为Xilinx创建新的内容。 为什么Xilinx难以获得免费许可证。 我在这个愚蠢的问题上浪费了几个小时。 以上来自于谷歌翻译 以下为原文 Yes it is node locked. That is what is giving me the problem. I generated it by going to the licensing page, asking for a WebPack license and having it emailed to me from Xilinx. When I tried to get a license using the built-in license manager (XLCM) tool, it did not work. I tried MANY times to get XLCM to give me a license but nothing happened. Now I cannot generate any new license because the License Manager web site says I already have one: The options are all disabled. Looks like I am completely screwed. I will just use my wife's email address and create a new accound with Xilinx unless you have any better suggestion. Why does Xilinx make it so difficult to get a FREE license. I have wasted hours on this stupid problem. |
这不是预期的,因为WebPack许可证应该是Node免费的。
我相信许可网站存在一些问题。 所以我提交了CR#804767来报告这个问题。 在修复之前,您可能需要为多台计算机生成多个许可证。 对不起,对不起。 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 This is not expected since WebPack license should be Node free. I believe there is some problem with licensing site. So I filed a CR # 804767 to report this problem. Before it is fixed you may need to generate more than one licenses for multiple machines. Sorry for the inconvienent. ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
它应该已经修复了。
如果删除许可证帐户中的当前webpack许可证,然后生成新的许可证,则不应立即要求您提供hostID。 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 It should have been fixed now. If you delete the current webpack license in the license account and then generate a new one, you should not be asked for a hostID now. ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
2415 浏览 7 评论
2821 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2292 浏览 9 评论
3372 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2458 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
1086浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
579浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
441浏览 1评论
2000浏览 0评论
723浏览 0评论
GMT+8, 2024-12-20 16:25 , Processed in 1.248126 second(s), Total 56, Slave 50 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
