电子发烧友论坛|
大家好,
我买了一块ML605电路板,它附带了一个凭证编号,用于生成许可证文件。 生成它时,我将其锁定到我的PC的MAC地址。 现在我想在不同的PC上使用ISE(我正在使用ISE 14.7),似乎我不能生成类似于前一个的另一个许可证。 我尝试使用Webpack许可证,但在Mapping中出现错误: 地图:258-尝试获取此体系结构的许可证时遇到问题。 在我的案例中,有没有办法在多台计算机上使用许可证? 谢谢。 菱镁 以上来自于谷歌翻译 以下为原文 Hi All, I bought a ML605 board and it came with a voucher number for me to generate a license file. When generating it, I locked it to my PC's MAC address. Now I want to use ISE(am using ISE 14.7) on a different PC and it seems I cannot generate another license similar to the previous one. I tried to use the Webpack license, but an error poped up in Mapping: Map:258- A problem was encountered attempting to get lthe license for this architecture. Is there a way to use a license on multiple computers in my case? Thanks. Lingmei |
3个回答
你好@玲妹,
您必须重新托管第二台机器的许可证。 请检查下面的AR以了解步骤 http://www.xilinx.com/support/answers/36136.html 问候,阿希什----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hello @lingmei, You have to rehost your license for second machine. Please check below AR to know the steps http://www.xilinx.com/support/answers/36136.html Regards, Ashish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ----------------------------------------------------------------------------------------------View solution in original post |
你好@玲妹,
您必须重新托管第二台机器的许可证。 请检查下面的AR以了解步骤 http://www.xilinx.com/support/answers/36136.html 问候,阿希什----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hello @lingmei, You have to rehost your license for second machine. Please check below AR to know the steps http://www.xilinx.com/support/answers/36136.html Regards, Ashish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 18:51 , Processed in 0.795853 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1662
