电子发烧友论坛|
你好,
我尝试了下面的连接,但是它给了很多错误。与其他部件一起使用门是不可能的吗? 以上来自于百度翻译 以下为原文 Hi, I tried the connections as below, but it gives a ton of errors. Is it not possible to use the gates with other components? |
7个回答
什么错误?最简单的检查总是在为我们提供工作空间包时。
鲍勃 以上来自于百度翻译 以下为原文 What errors? Easiest to check is always when you provide us with a workspace bundle. Bob |
谢谢鲍伯, 附加工作区束。问题是UART RX和缓冲输出连接之间。 AuthLogLogiGuest.Test.Cyrj.CaseVo.01.Zip 23.7 K 以上来自于百度翻译 以下为原文 Thanks Bob, Attaching the workspace bundle. Problem is between UART Rx and buffer output connection. |
xiaoke511812 发表于 2018-12-5 09:33 当然,你可以把RX连接到逻辑门。但是错误消息告诉您需要一个输入端连接到缓冲区。有时RX的输入是未定义的。为你的RX使用一个不同的门。 而且大门会被优化出来。你不能用这个作为延迟,不起作用。 鲍勃 以上来自于百度翻译 以下为原文 Of course you may connect Rx to logic gates. But the error message tells that you need an in-out terminal to connect to the buffer. There are times when the input to Rx is undefined. Use a different gate for your Rx. And: The AND gate will get optimized out. You cannot use this as a delay, will not work. Bob |
ncmza 发表于 2018-12-5 09:52 谢谢你的帮助,鲍伯! 我还能用什么其他的门呢?我只是想制作一条单线通信线路。而不是单独的RX和TX线。我认为PSOC门可以用来节省一些电路板空间,而不是使用外部的7HC126等。 以上来自于百度翻译 以下为原文 Thanks for the help Bob! What other gates can I use? I am simply trying to make a single wire communication line. Instead of separate RX and TX lines. I thought PSoC gates can be used to save some board space instead of using external 74HC126 etc. |
xiaoke511812 发表于 2018-12-5 10:08 你需要像MUX这样的东西来选择进入或走出的信号。将很难同步其他通信方。有一个单线接口,但它是缓慢的,不容易处理。 我建议让两线UART接口,因为它是很难写一个协议,有两个设备互相交谈。 你需要什么样的7HC126?RS232电平为+-12V,可由PSoC驱动高达5V。 鲍勃 以上来自于百度翻译 以下为原文 You will need something like a mux to select the signal coming in or going out. Will be difficult to sync the other communication side. There is a one-wire interface, but it is slow and not easy to handle. I would suggest to let the two-wire UART interface as it is, it will be difficult enough to write a protocol having two devices talk to each other. What do you need the 74HC126 for? RS232 levels are +-12V and up to 5V can be driven by the PSoC. Bob |
xiaoke511812 发表于 2018-12-5 10:08 我还能用什么其他的门呢?我只是想制作一条单线通信线路。而不是单独的RX和TX线。我认为PSOC门可以用来节省一些电路板空间,而不是使用外部的7HC126等。 如果在RS485模式下使用UART会有问题吗?使用发送方向信号将内部TX引脚从外部信号解耦(否则两个输出将被短路)。也许还有另一种可能的解决方案,显示您的电路或描述什么是可接受的(例如,PSoC RX和Tx引脚之间的电阻解耦,等等)。 当做 以上来自于百度翻译 以下为原文 What other gates can I use? I am simply trying to make a single wire communication line. Instead of separate RX and TX lines. I thought PSoC gates can be used to save some board space instead of using external 74HC126 etc.Would there be any problem if you use the UART in RS485 mode? Use the transmit direction signal to decouple the internal Tx pin from the external signal (otherwise the two outputs would get shorted). Maybe there's also another solution possible, show your circuit or describe what's acceptable (e.g. a resistor between PSoC Rx and Tx pin to decouple, etc.). Regards |
尼克特
单线UART通信可以在主从配置中完成。UART在RX状态下都处于空闲状态。要发送消息,主交换机切换到Tx模式,发送消息并进入空闲RX状态。从接收消息,进入Tx模式,响应,并返回到空闲RX状态。只有主人才能启动通信以避免碰撞。这样你就可以把PSoC和PSoC联系起来。每个UART应该通过BuoFe连接到IN OUT引脚,哪个方向由CuffReg控制。 奥迪赛1 以上来自于百度翻译 以下为原文 necdet, The single-wire UART communication can be accomplished in Master-Slave configuration. Both UARTs are idling in Rx state. To send message the Master switches to Tx mode, sends message and goes into idle Rx state. The slave receives message, goes into Tx mode, responds, and returns back into idle Rx state. Only Master can initiate communication to avoid collision. This way you can communicate PSoC to PSoC only. Each UART should be connected to in-out pin through bufoe, which direction is controlled by ControlReg. odissey1 |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
709浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7961浏览 2评论
/9
GMT+8, 2025-12-1 19:04 , Processed in 0.699991 second(s), Total 57, Slave 48 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1525
