我已下载ise 14.5并通过电子邮件发送了免费许可证。
我保存了文件并运行了许可配置管理器。 我将文件复制到默认文件夹,但该程序仍然告诉我,我没有许可证。 我错过了什么?我使用的是Windows 8,如果这有所不同。我能够创建一个新项目,但是当我实现它时,程序会出现许可错误并关闭。 如果我尝试打开之前制作的项目,该程序将再次关闭。您可以提供的任何帮助将不胜感激。谢谢哟 以上来自于谷歌翻译 以下为原文 I have downloaded ise 14.5 and was sent a free license by email. I saved the file and ran the license configuration manager. i copied the file to the default folder but the program still tells me that I don't have a license. Am I missing something? I am using windows 8 if that makes a difference. I am able to create a new project, but when I implement it the program gives a license error and closes. The program closes again if I try to open the previously made project. Any help you can provide would be greatly appreciated. Thank yo |
2个回答
HI,
Windows 8是ISE 14.5不支持的操作系统。 请看下面的第7页。 支持ISE 14.5操作系统的PDF http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_5/irn.pdf 在Xilinx许可证配置管理器中复制许可证文件后,您是否能够看到许可证功能信息的更新? 问候, 赛义德 -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 HI, Windows 8 is unsupported OS for ISE 14.5. Please have a look at page number 7 in the following. PDF for supported OS with ISE 14.5 http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_5/irn.pdf Are you able to see the license feature information getting updated after you copy the license file in Xilinx license configuration manager? Regards, Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
嗨,
正如现在提到的那样,Xilnix工具不支持Windows 8.但是为了确保您做的正确,请在下面查看提供许可文件路径的位置。 您可以在XILINXD_LICENSE_FILE位置((在许可证管理器中)提供许可证的完整路径,然后单击“设置”以设置运行ISE的环境变量。 谢谢, 谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, As alread mentioned presently Xilnix tools do not have support for Windows 8. However just to make sure you are doing the right thing, kindly check below on where to give the path to the license file. You can give the complete path to the license in the XILINXD_LICENSE_FILE location((In the license manager) and click on Set to set the environment variables for running ISE. thanks, Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution. |
只有小组成员才能发言,加入小组>>
2297 浏览 7 评论
2705 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2192 浏览 9 评论
3273 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2336 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
611浏览 1评论
1670浏览 1评论
171浏览 1评论
637浏览 0评论
1823浏览 0评论
GMT+8, 2024-9-11 02:51 , Processed in 1.245864 second(s), Total 81, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
