你好
我有激活许可证的问题。 我已经为Windows 8下载了ISE webpack12.4的许可文件,但是当我选择“复制许可”按钮时,它会关闭应用程序。 使用任何其他按钮时,只刷新应用程序,但不能用于其他任何操作。 我会感激任何回应。 谢谢。 以上来自于谷歌翻译 以下为原文 Hi I have a problem with activation license. I've already download the license file for ISE webpack12.4 for Windows 8 but when I pick 'copy license' button it closes the app. With any other button ir only refresh the app but doesn't work for anything else. I'll appreciate any response. Thanks. |
2个回答
嗨@nanni
您是否可以在此附上您的许可文件以确认它是基于激活的许可证还是基于证书的许可证? 基于激活的许可证不适用于ISE工具。& nbsp; 要使用ISE工具,您需要基于证书的许可证。 注意:为新查询/问题创建单独的线程始终是一种好习惯。 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi @nanni Can you attach your license file here to confirm whether it is activation based license or certificate based license? Activation based license do not work with ISE tools. To work with ISE tools, you need certificate based license. Note: It is always good practice to create a separate thread for new query/issue. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
ISE 12.4不支持Windows 8。
我们没有进行任何测试,因此预计会遇到许多奇怪的问题。 请尝试以下步骤: 1.将许可证文件复制到c:。Xilinx 2.创建一个环境变量'XILINXD_LICENSE_FILE'并将其值设置为“C:。Xilinx Xilinx.lic” -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 Windows 8 is not supported by ISE 12.4. No test has been made by us, so it's expected to get many strange problems. Please try the following steps: 1. copy the license file to c:.Xilinx 2. create an environment variable 'XILINXD_LICENSE_FILE' and set its value as "C:.XilinxXilinx.lic" ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 02:48 , Processed in 2.755222 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
853
