我打算通过LAN端口将Infiniivision 7000系列示波器连接到16803A逻辑分析仪。
是否需要交叉连接(交叉电缆或交叉适配器)来进行点对点连接? 我也在示波器论坛上问这个问题。 谢谢,JeffEdited:jpbledsoe于2013年9月25日上午8:35我找到了使用交叉电缆的方向。 我连接了电缆并为示波器加电。 范围表明它已配置为LAN。 在洛杉矶,设置/添加外部范围不再可用; 它在菜单选择中显示为灰色。 我在洛杉矶论坛上搜索了“添加外部范围”但没有找到的问题。 有关下一步尝试的建议吗? 杰夫 以上来自于谷歌翻译 以下为原文 I'm planning on connecting an Infiniivision 7000 series scope to a 16803A logic analyzer via their LAN ports. Will a crossover connection (crossover cable or crossover adaptor) be required for connecting them peer-to-peer? I'm asking this question in an oscilloscope forum as well. Thanks, Jeff Edited by: jpbledsoe on Sep 25, 2013 8:35 AM I found directions to use a crossover cable. I connected the cable and powered up the scope. The scope indicated that it had configured for the LAN. At the LA, Setup/Add External Scope is no longer available; it's grayed out in the menu selection. I searched the LA forums for problems with 'adding external scope' but found none. Any suggestions about what to try next? Jeff |
1个回答
范围和LA都需要IP地址。
由于您不在网络上,因此您必须设置它们,并且它们必须兼容。 我不知道如何设置示波器的地址,但LA是一台PC,所以你需要进入网络设置并设置一个。 像192.168.1.100和192.168.1.101这样的地址可以正常工作。 配置完成后,尝试从LA中ping范围。 您还可以查看两个仪器上LAN端口旁边的指示灯,看是否有任何指示灯。 根据LA的年龄,可能不需要交叉电缆。 较新的LA支持GBit以太网,它可以执行Auto-MDX,因此交叉或直线电缆应该可以工作。 这听起来像是一个需要解决的基本网络问题。 免责声明:为了获得更可靠的响应,您应该考虑致电当地的安捷伦技术呼叫中心。 安捷伦论坛在“可用”的基础上进行监控,并不一定是解决技术问题的最快方式。 以上来自于谷歌翻译 以下为原文 Both the scope and the LA need IP addresses. Since you're not on a network, you'll have to set them, and they have to be compatible. I don't know how to set the address of the scope, but the LA is a PC, so you need to go into the network settings and set one. Addresses like 192.168.1.100 and 192.168.1.101 will work well. Once you have them configured, try pinging the scope from the LA. You can also look at the lights next to the LAN port on both instruments to see if there are any lights. Depending on the age of the LA, a crossover cable might not have been necessary. The newer LA's support GBit Ethernet, which does Auto-MDX, so either a crossover or straight cable should work. It really sounds like a basic networking issue that needs to be resolved. Al Disclaimer: For more reliable response, you should consider calling your local Agilent Technical Call Center. The Agilent Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered. |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 04:20 , Processed in 0.785906 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2286
