电子发烧友论坛|
我可以理解不允许远程用户(即Windows远程桌面)访问完整许可证($$$),但这对于WebPack安装是否真的必要?
毕竟,它是免费下载和使用。 通常我只是下载/安装Webpack的另一个副本但是足迹很大*并且一次又一次地下载它对环境不利... 将Webpack用户从这个限制中解放出来的可能性有多大? 以上来自于谷歌翻译 以下为原文 I can understand not allowing remote users (i.e. Windows Remote Desktop) access to a full license ($$$) but is this really necessary for WebPack installations? After all, it is free to download and use. Ordinarily I'd just download/install another copy of the Webpack but the footprint is *huge* and downloading it again and again can't be good for the environment... What are the chances of freeing Webpack users of this restriction? |
3个回答
您使用的是什么版本的WebPACK?
我承认我不是授权专家 - 甚至通常使用WebPACK或终端服务。 但我拥有的WebPACK 11许可证有“TS_OK”条目,根据FAQ应支持此使用模式: http://www.xilinx.com/tools/faq.htm(许可,下载和安装常见问题解答) BT 以上来自于谷歌翻译 以下为原文 What version of WebPACK are you using? I'll admit I'm not the licensing expert - or even usually use WebPACK or terminal services. But the WebPACK 11 license I have has the "TS_OK" entry, which according to the FAQ should support this usage model: http://www.xilinx.com/tools/faq.htm (Licensing, Download & Installation FAQs) bt |
原来的计算机有ISE 11.1,我只是在另一个ISE 11.2上尝试过
这是我在使用远程桌面时从ISE 11.2获得的消息的一部分。 信息:安全:54 - 'xc3s200'是一个WebPack part.INFO:Security:61 - XILINXD_LICENSE_FILE环境变量不是set.INFO:Security:63 - LM_LICENSE_FILE环境变量不是set.INFO:Security:68 - 请运行 Xilinx许可证配置管理器(xlcm或“管理Xilinx许可证”)以帮助获取许可证.ERROR:安全性:9 - 没有'ISE'或'WebPack'功能可用于part'xc3s200'.------ -------------------------------------------------- --------------无法在Windows终端服务guestsession中签出不计数的许可证。功能:WebPack 顺便说一句,我没有在C:的许可文件中看到'TSK_OK'条目.Xilinx webpack.lic 以上来自于谷歌翻译 以下为原文 The original computer has ISE 11.1 and I just tried it on another with ISE 11.2 Here's part of the message I got from ISE 11.2 when using Remote Desktop. INFO:Security:54 - 'xc3s200' is a WebPack part. INFO:Security:61 - The XILINXD_LICENSE_FILE environment variable is not set. INFO:Security:63 - The LM_LICENSE_FILE environment variable is not set. INFO:Security:68 - Please run the Xilinx License Configuration Manager (xlcm or "Manage Xilinx Licenses") to assist in obtaining a license. ERROR:Security:9 - No 'ISE' nor 'WebPack' feature was available for part 'xc3s200'. ---------------------------------------------------------------------- Cannot checkout an uncounted license within a Windows Terminal Services guest session. Feature: WebPack BTW, I don't see a 'TSK_OK' entry in the license file located at C:.Xilinxwebpack.lic |
我刚刚使用11.4重新生成了一个WebPACK许可证,并注意到许可证与我已经拥有的许可证之间存在一些差异,包括显着缺少“TS_OK”标志。
这可能解释了为什么你不能在终端服务中使用它。 现在我考虑一下,我可能会在2009年4月发布11.1之前的早期版本中生成我的原始WebPACK 11许可证。我不确定为什么许可证现在不同但我看到它是...... 我建议联系开发系统客户服务(不同于技术支持的不同组),看看他们是否可以提供帮助。 http://www.xilinx.com/support/techsup/tappinfo.htm 干杯, BT 以上来自于谷歌翻译 以下为原文 I just regenerated a WebPACK license using 11.4 and noted a few differences in the license from the one I already had, including the notable absence of the "TS_OK" flag. That would likely explain why you can't use this within Terminal Services. Now that I think about it, I likely generated my original WebPACK 11 license with an early build before 11.1 was released last April 2009. I'm not sure why the license is different now but I see that it is... I would recommend contacting Development Systems Customer Service (a diffferent group than Tech Support) to see if they can help. http://www.xilinx.com/support/techsup/tappinfo.htm Cheers, bt
只有小组成员才能发言,加入小组>>
3138 浏览 7 评论
3433 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2895 浏览 9 评论
4094 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3079 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1356浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1194浏览 1评论
/9
GMT+8, 2025-12-10 12:43 , Processed in 0.690529 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2289
